1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget return timeout
To: Roberto Capobianco <[email protected]>
Cc: [email protected]
Date: Wed, 07 Jan 2009 11:16:26 +0100
May you start checking:
All Windows firewalls are turned off ?
All Linux firewalls are turned off ?
Both machine are into the same subnet? (ie LinuxIP = a.b.c.x and WinIP = a.b.c.y ?)
Hope this helps,
Mauro.
Roberto Capobianco wrote:
Hi all,
I am new to Epics world. This is my problem.
I installed epics 3.14 on two machines, one with fedora 10 and one with Windows XP SP3. No problem here.
I want to try the communication between them.
So i built an application from example template on both the machines. No problem here.
Then on the linux machine i setted the variables
export EPICS_CA_ADDR_LIST=(windows ip)
export EPICS_CA_AUTO_ADDR_LIST=NO
and on the windows machine i setted the variables
set EPICS_CA_ADDR_LIST=(linux ip)
set EPICS_CA_AUTO_ADDR_LIST=NO
I launched the applications without any error. I can see PVs with dbl command on both the machines.
Ok. Now when i do the command caget userHost:aiExample on the linux machine i can read the value but when i do the same command on the windows machine caget return the message "Channel connect timed out: userHost:aiExample not found".
The user is different between the two machines.
caRepeater is running on both machines.
What's wrong ? Thank You.
Robert
Mauro Giacchini
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
V.le dell’Universita', 2
35020 LEGNARO (PD) – ITALY
Tel. +39.049.8068558
Fax. +39.049.641925
EPICS _at_ LNL: http://www.lnl.infn.it/~epics/
caget return timeout Roberto Capobianco
Prev: caget return timeout Roberto Capobianco
Next: Re: caget return timeout Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
