1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: caget return timeout
To: <[email protected]>
Date: Wed, 7 Jan 2009 10:34:47 +0100
Hi all,
I am new to Epics world. This is my problem.
I installed epics 3.14 on two machines, one with fedora 10 and one with Windows XP SP3. No problem here.
I want to try the communication between them.
So i built an application from example template on both the machines. No problem here.
Then on the linux machine i setted the variables
export EPICS_CA_ADDR_LIST=(windows ip)
export EPICS_CA_AUTO_ADDR_LIST=NO
and on the windows machine i setted the variables
set EPICS_CA_ADDR_LIST=(linux ip)
set EPICS_CA_AUTO_ADDR_LIST=NO
I launched the applications without any error. I can see PVs with dbl command on both the machines.
Ok. Now when i do the command caget userHost:aiExample on the linux machine i can read the value but when i do the same command on the windows machine caget return the message "Channel connect timed out: userHost:aiExample not found".
The user is different between the two machines.
caRepeater is running on both machines.
What's wrong ? Thank You.
Robert
Re: caget return timeout Mauro Giacchini
Re: caget return timeout Ralph Lange
Prev: RTYP field through the PV Gateway Ernest L. Williams Jr.
Next: Re: caget return timeout Mauro Giacchini
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: RTYP field through the PV Gateway Jeff Hill
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
