1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: RTYP field through the PV Gateway
To: "'Andrew Johnson'" <[email protected]>
Cc: [email protected], "'Ernest L. Williams Jr.'" <[email protected]>
Date: Wed, 7 Jan 2009 09:25:23 -0700
Summarizing the issue; this PV attribute, "DBR_CLASS_NAME", isn't currently
maintained in the gateway's cache. The symptom must be that its
communicating properly through both sides of CA, but not through the
gateway.
I am not aware that anyone is working on this, but Ralph Lange would be the
best person to consult concerning current projects in progress with the
gateway.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Andrew Johnson
> Sent: Wednesday, January 07, 2009 8:29 AM
> To: [email protected]
> Cc: Ernest L. Williams Jr.
> Subject: Re: RTYP field through the PV Gateway
> Hi Ernest,
> On Wednesday 07 January 2009 00:15:17 Ernest L. Williams Jr. wrote:
> > Is anyone working to add the "DBR_CLASS_NAME" to the gateway so that it
> > handles the RTYP field in an EPICS record?
> I'm not aware of anybody doing so.  Why can't you just ask for the .RTYP
> field
> name (which is really an automatically created record attribute) directly?
> - Andrew
> The best FOSS code is written to be read by other humans -- Harold Welte
RTYP field through the PV Gateway Ernest L. Williams Jr.
Re: RTYP field through the PV Gateway Andrew Johnson
Prev: Re: initial(init_value) rule within a field sometimes works - follow up Andrew Johnson
Next: EPICs base MingW32 compilation failed ! URIOT Didier
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RTYP field through the PV Gateway Andrew Johnson
Next: caget return timeout Roberto Capobianco
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
