Hello,
I tried to compile EPICS base 3.14.10 on a windows computer with gcc 3.4.5
I followed the install instruction, and compilation started correctly but after a fews secondes I had the following message.
......ommon -I. -I.. -I../../../include/os/WIN32 -I../../../include ../netWrit
eNotifyIO.cpp g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -I. -I../O.C ommon -I. -I.. -I../../../include/os/WIN32 -I../../../include ../netSubs cription.cpp g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -I. -I../O.C ommon -I. -I.. -I../../../include/os/WIN32 -I../../../include ../tcpSend Watchdog.cpp ../tcpSendWatchdog.cpp:73: internal compiler error: Segmentation fault Please submit a full bug report, with preprocessed source if appropriate. See <URL:http://www.mingw.org/bugs.shtml> for instructions. mingw32-make[3]: *** [tcpSendWatchdog.o] Error 1 mingw32-make[3]: Leaving directory `D:/Cpp/epics_3.14.10/base/src/ca/O.win32-x86 -mingw' mingw32-make[2]: *** [install.win32-x86-mingw] Error 2 mingw32-make[2]: Leaving directory `D:/Cpp/epics_3.14.10/base/src/ca' mingw32-make[1]: *** [ca.install] Error 2 mingw32-make[1]: Leaving directory `D:/Cpp/epics_3.14.10/base/src' mingw32-make: *** [src.install] Error 2 Have you already see this type of problem ?
Thank,
Best regards
| ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
