Hi Ivan,
On Wednesday 24 December 2008 04:29:41 ivan wrote:
> I found that although I had done a make clean the iocpsc.db file that I
> had created in the Db folder was not updated in the db folder after
> make. So manually copying the file to the db folder curred the problem.
> I could then initialize all my fields from the substitute file.
> Maybe there is another param for the make process that would have
> updated this file, as I said "make clean" didn't do the trick.
How are you generating and installing the iocpsc.db file? If you post the
contents of your xxxApp/Db/Makefile we might be able to help. If you wrote
your own rule you probably want to write a clean:: rule as well to delete
the .db files you generate, or make sure that the .db files are listed in the
TARGETS variable which is included in a built-in clean:: rule.
Writing rules for EPICS Makefiles is a little different than with other
packages because of the way that we share the Makefile between the source
directory and build directory; you might want to study the file at
<base>/configure/RULES.Db to look at the rules that we provide for database
files, documentation for which is mostly in section 4.6.10 of the Application
Developers' Guide.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: RTYP field through the PV Gateway Andrew Johnson
RE: RTYP field through the PV Gateway Jeff Hill
<2009>
2025
2026
Re: caget return timeout Ralph Lange
EPICs base MingW32 compilation failed ! URIOT Didier
<2009>
2025
2026
