1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICs base MingW32 compilation failed !
To: URIOT Didier <[email protected]>
Cc: [email protected]
Date: Thu, 08 Jan 2009 14:56:55 +0100
URIOT Didier schrieb:
> Hello,
> I tried to compile EPICS base 3.14.10 on a windows computer with gcc 3.4.5
> I followed the install instruction, and compilation started correctly
> but after a fews secondes I had the following message.
Consider going back to gcc 3.4.2 (MinGW 4.1.1), which hasn't that problem.
You can get older releases from the mirror sites as described here:
http://www.mingw.org/old/download.shtml
Jens
Re: EPICs base MingW32 compilation failed ! Andrew Johnson
EPICs base MingW32 compilation failed ! URIOT Didier
Prev: Gateway fails with "epicsMutex pthread_mutex_lock failed: error Invalid argument" Mark Bennett
Next: Scilab and epics Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICs base MingW32 compilation failed ! Andrew Johnson
Next: Re: EPICs base MingW32 compilation failed ! Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
