1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MAXvSetup is an undefined symbol
To: <[email protected]>, <[email protected]>, "Ronald L. Sluiter" <[email protected]>
Cc: [email protected]
Date: Wed, 14 Jan 2009 21:22:33 -0600
FYI this problem is resolved
Sent: Wed 1/14/2009 9:09 PM
To: Mark Rivers
Subject: ??: MAXvSetup is an undefined symbol
Hi, That works. Thank you very much.
No.239 Zhangheng Road
PuDong District
Shanghai Institute of Applied Physics CAS
Shanghai, China
Tel: +86-21-33933256  Fax: +86-21-33933031
-----Original Message-----
Sent: 2009-1-14 (???) 21:57
To: ???
Cc: [email protected]; Ronald L. Sluiter; [email protected]
The problem is with the Makefile-3 file you sent (which is motorApp/OmsSrc/Makefile).  That is NOT the file that came with the motor distribution, someone has altered it greatly.  The version you sent builds an oms "PROD_IOC", not an oms library, which is your problem.  It is not a good idea to modify the Makefile or other code in the distribution except to comment or uncomment things, because it leads to this confusion.
Here is your Makefile, the one you sent me:
# Makefile
TOP = ../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# The following are used for debugging messages.
#!USR_CXXFLAGS += -DDEBUG
PROD_IOC_vxWorks += oms
DBD +=oms.dbd
DBD +=devOms.dbd
oms_DBD +=base.dbd
oms_DBD += motorSupport.dbd
oms_DBD += devOms.dbd
oms_DBD += devSoftMotor.dbd
#oms_DBD += calc.dbd
#oms_DBD += aCalcoutRecord.dbd
#oms_DBD += calcSupport.dbd
#oms_DBD += sCalcoutRecord.dbd
#oms_DBD += swaitRecord.dbd
oms_DBD += transformRecord.dbd
oms_SRCS_vxWorks += oms_registerRecordDeviceDriver.cpp
oms_SRCS_DEFAULT += omsMain.cpp
# The following is required for the OMS PC68/78 (i.e., devOmsPC68) device driver.
#oms_SRCS_vxWorks += devOmsPC68.cc drvOmsPC68.cc
# The following is required for the OMS VME8/44 (i.e., devOMS) device driver.
oms_SRCS_vxWorks += devOms.cc drvOms.cc
# The following is required for the OMS VME58 (i.e., devOms58) device driver.
oms_SRCS_vxWorks += devOms58.cc drvOms58.cc
# The following is required for the OMS MAXv device driver.
oms_SRCS_vxWorks += devMAXv.cc drvMAXv.cc
# The following is required for all OMS device drivers.
oms_SRCS_vxWorks += devOmsCom.cc
oms_LIBS += motor
oms_LIBS += SoftMotor
#oms_LIBS += asyn
oms_LIBS += calc
oms_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
oms_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
I have attached the current version of OmsSrc/Makefile.  Here it is.  Note that it builds a LIBRARY_IOC, not a PROD_IOC.
# Makefile
TOP = ../..
DBD += devOms.dbd
LIBRARY_IOC_DEFAULT += oms
ifdef ASYN
SRCS += devOmsPC68.cc drvOmsPC68.cc
endif
SRCS += devOms.cc drvOms.cc
SRCS += devOms58.cc drvOms58.cc
SRCS += devMAXv.cc drvMAXv.cc
SRCS += devOmsCom.cc
oms_LIBS += motor
ifdef ASYN
oms_LIBS += asyn
endif
This is from motor R6-4, and I think you are running R6-2.  There are some minor difference which are shown here:
corvette:6-4beta/motorApp/OmsSrc>cvs diff -rR6-2 Makefile
Index: Makefile
RCS file: /net/beams-nfs/export/local/cvs/support/motor/motorApp/OmsSrc/Makefile,v
retrieving revision 1.7
retrieving revision 1.12
diff -u -r1.7 -r1.12
--- Makefile    2006/04/24 19:55:05     1.7
+++ Makefile    2008/09/17 21:48:58     1.12
@@ -10,10 +10,11 @@
 DBD += devOms.dbd
-LIBRARY_IOC_WIN32 += -nil-
+ifdef ASYN
+endif
@@ -28,6 +29,9 @@
 oms_LIBS += motor
+ifdef ASYN
+oms_LIBS += asyn
+endif
Please go back to the original files in the motor distribution and build those. It will create an oms library, which should work fine.
Sent: Tue 1/13/2009 11:23 PM
To: Mark Rivers
hello, thanks for your kindness. Please check the files in attachment.
PuDong District
Shanghai, China
Sent: 2009-1-14 (???) 11:56
To: ???
There is some problem if the oms library is not being built.
At the top level in motor please do the following:
make clean uninstall
make
and send me the complete output.
Also send me the contents of motor/Makefile and motor/motorApp/Makefile where motor is your top level directory for motor.
Sent: Tue 1/13/2009 9:11 PM
To: Mark Rivers
Thanks for your advice. The OmsSrc directory is not commented, but in the lib directory only have libmotor and libsoftmotor. I am still do not know which line determine weather obtain the lib file after compiled.
PuDong District
Shanghai, China
Sent: 2009-1-14 (???) 10:49
To: ???; [email protected]
Depending on which version of the motor module you are using you may need to edit motorApp/Makefile to uncomment the line to build the OmsSrc directory.  That is the correct way to do it, then you won't have to copy the source files to your application directory.
Sent: Tue 1/13/2009 7:11 PM
To: Mark Rivers; [email protected]
If i don't compile the source file , there will be some error about oms:
ld < mx.munch
Undefined symbol: pvar_dset_devOMS (binding 1 type 0)
Undefined symbol: pvar_dset_devMAXv (binding 1 type 0)
Undefined symbol: pvar_drvet_drvOms (binding 1 type 0)
Undefined symbol: pvar_drvet_drvMAXv (binding 1 type 0)
Undefined symbol: pvar_dset_devOms58 (binding 1 type 0)
Undefined symbol: pvar_drvet_drvOms58 (binding 1 type 0)
ld error: Module contains undefined symbol(s) and may be unusable.
value = 0 = 0x0
Then i check the files, i did not find the oms library. So i have to compile the source directly. The reason for my problem is i don't have oms library after i compiled the motor support in the lib or other directory.
PuDong District
Shanghai, China
Sent: 2009-1-13 (???) 22:29
You are doing things differently than we normally do.  You are compiling the motor files (motorRecord.cc, devMAXv.cc, etc.) directly as part of your application with the lines like:
mx_SRCS_vxWorks += motorRecord.cc motordevCom.cc motordrvCom.cc
but you are also including those same routines again via external libraries with lines like:
mx_LIBS += motor
mx_LIBS += SoftMotor
As noted yesterday you are not including oms as an external library, which you should.
I suggest that you do not compile the motor or oms code again as part of your application, but rather just include the libraries from the motor module.
This works fine for me under vxWorks with the vxWorks shell, I do not have problems with C++ name mangling and MAXvSetup works with no problems.
Sent: Mon 1/12/2009 5:42 AM
To: [email protected]
Subject: MAXvSetup is an undefined symbol
Hello,everyone.
I have two application of oms motor and hytec adc, but i only have a VME crate. So i need to merget the two application to one ioc. The oms motor application from
synApps and hytec 8401 work well respectively. So i use the makeBaseApp.pl to produce a new application and revise the makefile, and copy the source file to the
corresponding directory. The compile is ok, i can get the munch and st.cmd files.
When download st.cmd to the vme, there are will problems. It is said the MAXvSetup is an undefined symbol. It is very strange. I insert the hytec8001 and 8401 in the
first and the VME in the third.
Please give me some advice and idea.
Thanks.
----------------------Makefile-----------------------------------------
TOP=../..
# build an ioc application
PROD_IOC_vxWorks = mx
DBD += mx.dbd
# mx.dbd will be made up from these files:
mx_DBD += base.dbd
#include definitions for any other support applications needed
#mx_DBD += xxx.dbd
mx_DBD += transformRecord.dbd
mx_DBD += oms.dbd
mx_DBD += motorSupport.dbd
mx_DBD += motorRecord.dbd
mx_DBD += devOms.dbd
mx_DBD += devSoftMotor.dbd
mx_DBD += PSU0.dbd
mx_DBD += sscan.dbd
# <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd
mx_SRCS_vxWorks += mx_registerRecordDeviceDriver.cpp
mx_SRCS_DEFAULT += mxMain.cpp
mx_SRCS_vxWorks += -nil-
mx_SRCS_vxWorks += devOms.cc drvOms.cc
mx_SRCS_vxWorks += devOms58.cc drvOms58.cc
mx_SRCS_vxWorks += devMAXv.cc drvMAXv.cc
mx_SRCS_vxWorks += devOmsCom.cc
mx_SRCS_vxWorks += devSoft.cc devSoftAux.cc
#The following adds support from base/src/vxWorks
mx_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
#add a definition for each support application used by this application
#mx_LIBS += xxx
#NOTES:
#      1)It is not possible to build sncExample both as a component of mx
#        and standalone. You must choose only one.
#      2)To build sncExample SNCSEQ must be defined in <top>/configure/RELEASE
#The following builds sncExample as a component of mx
#mx_SRCS += sncExample.stt
#mx_LIBS += seq pv
mx_LIBS += motor
mx_LIBS += Ipac
mx_LIBS += Hy8402ip
mx_LIBS += Hy8401ip
mx_LIBS += calc
mx_LIBS += sscan
mx_LIBS_vxWorks += $(EPICS_BASE_IOC_LIBS)
#The following builds sncExample as a standalone application
#PROD_HOST += sncExample
#sncExample_SNCFLAGS += +m
#sncExample_SRCS += sncExample.stt
#sncExample_LIBS += seq pv
#sncExample_LIBS += $(EPICS_BASE_HOST_LIBS)
-----------------------------Error mesg--------------------------------
ld < mx.munch
sysAtReboot not found. epicsExit will not be called by reboot.
value = 516036768 = 0x1ec218a0
cd top
value = 0 = 0x0
dbLoadDatabase("dbd/mx.dbd",0,0)
value = 0 = 0x0
mx_registerRecordDeviceDriver(pdbbase)
value = 0 = 0x0
## motor
dbLoadRecords("db/att.db")
value = 0 = 0x0
MAXvSetup(1,16,0xF000,180,6,10)
undefined symbol: MAXvSetup
PuDong District
Shanghai, China
MAXvSetup is an undefined symbol 汪启胜
RE: MAXvSetup is an undefined symbol Mark Rivers
答复: MAXvSetup is an undefined symbol 汪启胜
Prev: virtual linac with libstdc++.so.6 Pierrick Hanlet
Next: Re: virtual linac with libstdc++.so.6 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MAXvSetup is an undefined symbol Mark Rivers
Next: AreaDetector, Compiling synApps modules for Windows Microsoft compiler Timothy Madden
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
