1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using SynApps Calc Module
To: "Mark Rivers" <[email protected]>, "epics" <[email protected]>
Date: Sat, 17 Jan 2009 21:40:40 -0000
Thanks Mark
Forgot to say I had already added the following to my apps configure/RELEASE file, based on looking at what else was already in there.
CALC=/home/steve/epics/calc/2-6-7
This directory is where I had extracted the calc module and done a make. So it contains a lib/linux-x86 directory containing libcalc.a and libcalc.so.
Is the second dbd step necessary for the app make?
Steve
----- Original Message ----- From: "Mark Rivers" <[email protected]> To: "Steve Kinder" <[email protected]>; "epics" <[email protected]>
Sent: Saturday, January 17, 2009 8:34 PM
Subject: RE: Using SynApps Calc Module
Just add the path to the calc module to your applications configure/RELEASE file.
You don't need to do anything with LD_LIBRARY_PATH.
You do also need to add calcSupport.dbd to you application's xxxInclude.dbd file.
Sent: Sat 1/17/2009 1:54 PM
To: epics
Subject: Using SynApps Calc Module
I am trying to use the SynApps calc module in a Linux IOC. I would like to
use sCalcout records in my application. The calc documentation says to
include calcSupport.dbd and link to libcalc. Trying to do the 2nd part first
I tried adding lines like app_LIBS += calc in my Makefiles but I get errors
like
No rule to make target ..... libcalc.a ....
I have already downloaded the calc module and done the make. I hoped adding
the calc lib directory to my LD_LIBRARY_PATH  would then make the
application link work.
Could anyone offer me some advice on how to link libcalc with my application
please.
Thanks
Steve
RE: Using SynApps Calc Module Mark Rivers
Using SynApps Calc Module Steve Kinder
Prev: RE: Using SynApps Calc Module Mark Rivers
Next: RE: Using SynApps Calc Module Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
