1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EDM freezes
To: "John Dobbins" <[email protected]>, "Brian Bevins" <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 21 Jan 2009 09:10:02 -0800
Thanks to both,
In my case EDM freezes completely, so that it has to be killed with the kill command.
It sounds like I need to get a newer version of EDM (1-11-1z).
Zen
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of John Dobbins
Sent: Wednesday, January 21, 2009 8:52 AM
To: Brian Bevins
Cc: EPICS Techtalk
Subject: Re: EDM freezes
I believe we also see the second behavior but I think it it occurs with only some of our screens.
edm version 1-10-1zb on Scientific Linux SL release 4.5 (Beryllium)
John Dobbins
Brian Bevins wrote:
> Hi Zen,
> It depends on exactly what you mean when you say the EDM "freezes".
> What you're describing might be an instance of one of two known problems.
> 1) There were problems with embedded and related displays that were
> not fully resolved until 1-11-1z. The problem was especially acute
> with "on focus" related displays that pop up when you just mouse over
> the widget with no click, but there were other associated issues with
> embedded and related displays. Depending on the specific version you
> could see anything from stuck popups that won't close to EDM freezing
> completely (no screen redraws at all) to EDM crashing.
> 2) There is a more subtle ongoing problem that (as far as I know) has
> only been reported here at Jefferson Lab. When an EDM session has been
> left running for a long (variable) time, the widgets will stop
> updating despite the fact that the PV values are still changing. There
> is no visual clue that anything is wrong, unless you can see the same
> PV's in a different app or a separate EDM session. Usually everything
> will start updating again if you open or close a display, or even
> expose a covered display. This issue only started when we moved from
> HP-UX to RedHat Enterprise Linux. It has not yet been resolved.
> Hope that helps.
> --Brian
> Szalata, Zenon M. wrote:
>> I am observing that EDM freezes with my application which uses a
>> number of related displays.  This happens when I pop up the related
>> displays a few times.  It is not very reproducible, sometimes it
>> happens after a few clicks on the related display buttons, at other
>> times the application will survive many such clicks.
>> I have a vague memory of an e-mail when someone else reported a
>> similar problem, but I cannot find any evidence of that.
>> I am currently using edm 1.11.1t.
>> Is this a known problem and if so, has the issue been resolved?
>> Thanks in advance,
>> Zen
Re: EDM freezes John Sinclair
EDM freezes Szalata, Zenon M.
Re: EDM freezes Brian Bevins
Re: EDM freezes John Dobbins
Prev: Re: EDM freezes John Dobbins
Next: Re: Multithreading in R3.14.9 - preemptive callbacks not working. Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EDM freezes John Sinclair
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
