1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM freezes
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 21 Jan 2009 17:17:55 -0500
2) There is a more subtle ongoing problem that (as far as I know) has only been reported here at Jefferson Lab. When an EDM session has been left running for a long (variable) time, the widgets will stop updating despite the fact that the PV values are still changing. There is no visual clue that anything is wrong, unless you can see the same PV's in a different app or a separate EDM session. Usually everything will start updating again if you open or close a display, or even expose a covered display. This issue only started when we moved from HP-UX to RedHat Enterprise Linux. It has not yet been resolved.
It would be interesting to know more about this. If you mouse over
a display element like a text control and do a control-middle-mouse click you will get something like the following in the message window.
Text Control (105,46): b:Vgc12-1Ig1:PressureR
  Host: orib60.phy.ornl.gov:5064
  Num times conected = 1
  Num times disconected = 0
  Num value changes = 1
  Num references = 2
  Time stamp = Wed Jan 21 17:11:00 2009
It would be nice to know if the various pvs that were no longer updating
had any things in common like hostname, timestamp, or if any of the numeric values looked fishy (negative values, etc.).
John Sinclair
Re: EDM freezes Brian Bevins
EDM freezes Szalata, Zenon M.
Re: EDM freezes John Dobbins
RE: EDM freezes Szalata, Zenon M.
Prev: RE: Multithreading in R3.14.9 - preemptive callbacks not working. Douglas Morrison
Next: Re: EDM freezes Dave Reid
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EDM freezes Szalata, Zenon M.
Next: Re: EDM freezes Brian Bevins
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
