1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: vdct problem with quoted strings
To: "epics" <[email protected]>
Date: Thu, 22 Jan 2009 20:27:44 -0000
I have seen what may be a bug with vdct when using quoted strings in fields. This has occured when using these strings in the calc fields of scalcout records. As an example using calcs like A=6?0:dbl(AA["X ","Z"]). vdct saves this as field(CALC, "A=6?0:dbl(AA[\"X \",\"Z\"])"). Fine. However when running vdct again and loading these fields back in they all seem to be truncated after the first \.
Not sure there will be an easy workaround this. I believe the quotes within the field are necessary. Just wanted to report it somewhere as it seems like a bug.
Steve
Re: vdct problem with quoted strings Andrew Johnson
Prev: Re: Very slow reconnection to medm after IOC reboot J. Lewis Muir
Next: Re: vdct problem with quoted strings Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MEDM EPICS Win32 Extensions Richard Pastrick
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
