1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MEDM EPICS Win32 Extensions
To: "J. Lewis Muir" <[email protected]>
Date: Thu, 22 Jan 2009 16:15:51 -0800
I switched over to Xming and that works so I guess that is ok.
Thanks for the suggestion.
-Richard
-----Original Message-----
Sent: Thursday, January 22, 2009 3:49 PM
To: Richard Pastrick
Cc: Paul Sichta; [email protected]
Subject: Re: MEDM EPICS Win32 Extensions
On 1/22/09 6:20 PM, Richard Pastrick wrote:
> I have run into that before but that is not the problem. I have the
> mouse hovering over the text field in question and nothing is entered.
> I was reading up on a previous thread on tech talk where my exact
> problem was reported but the fix does not help my situation.
> http://www.aps.anl.gov/epics/tech-talk/2007/msg01116.php
> I also did a search to see if the issue was related specifically to
> cygwin and it appears to be so. I believe it has to do with the
> environment variable XKEYSYMDB. If it is set, I cannot use xterm or
> medm.
> Anyone have any other thoughts? This is a fresh install of cygwin and
> I copied the XKeySymDB file from this cygwin install to the epics dir
> and pointed the environment variable at that.
> Thanks.
> -Richard
Hi, Richard.
Do you get any error messages?  Do you have a .xsession-errors file in
your home directory with anything relevant in it?
Another possibility might be to try Xming to see if that makes a
difference:
  http://www.straightrunning.com/XmingNotes/
Lewis
 The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed.  Any use of this email for any other purpose is prohibited.  If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
MEDM EPICS Win32 Extensions Richard Pastrick
Re: MEDM EPICS Win32 Extensions Paul Sichta
RE: MEDM EPICS Win32 Extensions Richard Pastrick
Re: MEDM EPICS Win32 Extensions J. Lewis Muir
Prev: Re: MEDM EPICS Win32 Extensions J. Lewis Muir
Next: Re: RTEMS soft reboot Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: vdct problem with quoted strings Steve Kinder
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
