1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Very slow reconnection to medm after IOC reboot
To: Jeff Hill <[email protected]>
Cc: "'epics'" <[email protected]>
Date: Mon, 26 Jan 2009 09:56:41 -0600
On Friday 23 January 2009 16:40:22 Jeff Hill wrote:
> But perhaps this would work just as well (with very fast reconnect times)
> O rebuild the application
> O reboot the IOC
Unfortunately on Windows this is not possible; installing a new version of
a .DLL or .EXE is not permitted by the OS until all programs using it have
quit, thus one has to stop the IOC before the rebuild can be started.
> Nevertheless, if by chance one ends up with the first scenario, restarting
> the MEDM screen isn't, from my perspective, exactly heavy lifting -
> considering that we are presumably waiting at the edge of the seat for the
> channel's to reconnect. Synchronization might be the primary aggravation,
> but perhaps it will even be successful the first try if one waits
> approximately long enough for the IOC to finish rebooting before restarting
> the medm screen.
For the moment that does appear to be Mark's only alternative to waiting the 4
minutes, but this is not an acceptable long-term solution (and contrary to
what you say below, this needs to be fixed in R3.14 since it got broken in
R3.14).  I'd like to have a discussion (on core-talk or at the codeathon)
about other reconnection algorithms that could be used to fix this while
still protecting the network from the UDP storms that we used to get.
> I am busy with other projects at the moment, but perhaps you might consider
> creating a mantis entry (we want to minimize changes to R3.14 so this would
> be against R3.15) describing the problem (and including a copy of this mail
> exchange), and perhaps some improvements can be made (within the
> constraints of reliable operation of course).
I have filed Mantis bug #330 which refers to this tech-talk discussion thread
for the details.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
RE: Very slow reconnection to medm after IOC reboot Jeff Hill
RE: Very slow reconnection to medm after IOC reboot Mark Rivers
Prev: Re: RTEMS soft reboot Till Straumann
Next: RE: Very slow reconnection to medm after IOC reboot Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Very slow reconnection to medm after IOC reboot Jeff Hill
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
