1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: wrong timestamps in monitors
To: "EPICS tech-talk" <[email protected]>
Date: Thu, 29 Jan 2009 13:04:09 -0600
Benjamin Franksen wrote:
> - If the field does not have the PP property, then the record is not
> processed as a result of the put, and the CA event is posted with the old
> timestamp.
> - If the field /does/ have the PP property, then the record gets processed
> as a result of the put, which woudl update the record's timestamp, but
> processing comes /after/ EPICS base posts the event, thus the event has the
> wrong (old) timestamp.
To try and state the problem succinctly: you can only be sure that a timestamp
reflects the time when the value was recorded if you're looking at a field
which can only get updated as a result of record processing, i.e. one that is
marked  by the RecRefManual with a Yes in the "Rec Proc Monitor" column and
a "No" in the "Modify" column.  There are actually very few of those...
BTW, the VAL field is special; the runtime currently assumes that the record
type will always post monitors on VAL when the record is processed, thus the
dbPut() routine deliberately avoids posting monitors on VAL if it is marked
PP=YES.  Your second paragraph above thus does not apply to VAL fields.  You
can confirm that by monitoring the VAL field of a sequence (seq) record, the
process routine of which only posts monitors on VAL when the alarm
status/severity of the record changes — while monitoring it, you can change
VAL as much as you like and the monitor won't update even though the record
is processing (set TPRO to confirm that).
It is currently very well-defined what the timestamp returned by a DBR_TIME
request through CA holds; it gives the value of the TIME field of the record
containing the PV, read atomically with the value and other attributes that
came with it.  A record's TIME field also has a well-defined meaning; it
indicates when that record was last processed (although strictly speaking the
behavior is record-type specific).  Thus I disagree with your Subject: line;
the timestamps provided with the monitor are not actually wrong, they just
don't necessarily reflect the time when that PV data was stored.
> It should be clear that this means one should /not/ trust the history of
> value changes as e.g. reported by the channel archiver (or simply the
> output of camonitor) whenever the PV in question references a non-VAL
> field. At least not w.r.t. the reported timestamps.
Thus I think the fundamental issue here is not really in the database at all;
I'd argue instead that the Channel Archiver is misusing the timestamp it gets
from CA.  It would *like* it to reflect the time when the data was recorded,
but the IOC has never claimed that it provides that information.  One could
make that assumption for some channels, but not for all.
I believe it is well-recognized that the status and severity of a PV reflect
the state of the record containing that PV rather than the state of PV value
itself.  If I'm looking at the DESC field of a record, I can still rely on
the string returned even when the state I get with it is UDF/INVALID.  It is
unfortunate that the similar disconnect may have been forgotten for
timestamps.
> Is this going to be addressed any time soon?
I suggest that the place to fix that problem is in the Channel Archiver, not
in the IOC.  The configuration file needs to be able to tell the Archiver for
each PV whether to use the timestamp from CA or to record a local timestamp
whenever it receives a monitor callback or polls for an update.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: wrong timestamps in monitors Dirk Zimoch
Re: wrong timestamps in monitors Goetz Pfeiffer
Re: wrong timestamps in monitors Benjamin Franksen
Prev: RE: wrong timestamps in monitors Dalesio, Leo
Next: Re: recordGenerator record Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: wrong timestamps in monitors Dirk Zimoch
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
