1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: wrong timestamps in monitors
To: EPICS tech-talk <[email protected]>
Date: Fri, 30 Jan 2009 10:08:23 +0100
Andrew Johnson wrote:
Thus I think the fundamental issue here is not really in the database at all; I'd argue instead that the Channel Archiver is misusing the timestamp it gets from CA. It would *like* it to reflect the time when the data was recorded, but the IOC has never claimed that it provides that information. One could make that assumption for some channels, but not for all.
I believe it is well-recognized that the status and severity of a PV reflect the state of the record containing that PV rather than the state of PV value itself. If I'm looking at the DESC field of a record, I can still rely on the string returned even when the state I get with it is UDF/INVALID. It is unfortunate that the similar disconnect may have been forgotten for timestamps.
Is this going to be addressed any time soon?
I suggest that the place to fix that problem is in the Channel Archiver, not in the IOC. The configuration file needs to be able to tell the Archiver for each PV whether to use the timestamp from CA or to record a local timestamp whenever it receives a monitor callback or polls for an update.
- Andrew
I see that the current implementation is that a monitor
provides the timestamp when the record was last processed.
But if you look, for example, with "camonitor" on a PV,
you would expect the timestamp the program shows in the same line
has something to do with the time the PV changed.
Here I have an example:
U125ID2R:BaseParGapsel.B       2009-01-29 09:07:10.455966 150
U125ID2R:BaseParGapsel.B       2009-01-29 09:07:10.455966 1000
U125ID2R:BaseParGapsel.B       2009-01-29 13:26:11.956084 185
at 13:26 I wrote "1000" to the PV. The record the processed and
changed it's field B to 185. If I look at the output
I would assume that the value changed at 09:07. This is wrong
by about 4 and a half hours. I do not know how long in the past I stared
at print-outs from camonitor or the archiver trying to debug my
database and wondering what happened just because the timestamps
do not always show the time the PV did change.
The conclusion is that timestamps for non-value fields only show
that the value changed some time after the given timestamp, it may
be seconds, months or years later. I would expect that this
non intuitive behavior is at least documented somewhere. It obviously
violates the principle of the least surprise.
-- Goetz
Helmholtz-Zentrum Berlin für Materialien und Energie GmbH Glienicker Straße 100, 14109 Berlin Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph Stellvertretende Vorsitzende: Dr. Jutta Koch-Unterseher Geschäftsführer: Prof. Dr. Anke Rita Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer Sitz der Gesellschaft: Berlin Handelsregister: AG Charlottenburg, 89 HRB 5583 Information: Durch die Fusion mit dem ehemaligen Hahn-Meitner-Institut (HMI) ist BESSY nun Teil des neuen Helmholtz-Zentrum Berlin für Materialien und Energie (HZB). By the merger with the former Hahn-Meitner-Institut (HMI), BESSY became part of the new Helmholtz-Zentrum Berlin für Materialien und Energie (HZB). Disclaimer automatically attached by the E-Mail Security Appliance mail0.bessy.de 01/30/09 at Helmholtz-Zentrum Berlin GmbH.
RE: wrong timestamps in monitors Mark Rivers
wrong timestamps in monitors Benjamin Franksen
Re: wrong timestamps in monitors Andrew Johnson
Prev: Re: wrong timestamps in monitors Dirk Zimoch
Next: RE: wrong timestamps in monitors Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: wrong timestamps in monitors Dalesio, Leo
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
