1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: boot vxworks from ppcbug in mv5100
To: Matt Rippa <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 03 Feb 2009 10:11:28 +0800
Hi  Matt,
  Thanks a lot for your replay.I think the flash bank A has some physical problem.
It can not be reprogramed in ppcbug.
  I have loaded vxworks bootrom and ramimage into ram by ppcbug.Some version of ram image
can run, but can not excute many shell command, like i, reporting instruction pointer
exception.All version of bootrom can not run.I have checked the code of bootrom and find
that at some instruction initializing memory part,bootrom will run fly.
  So, I have a question, is the memory map in ppcbug same as in vxworks?And what job should
I do in  _sysInit?Because there are so many difference between sysInit(sysAlib.s) and romInit(romInit.s),
I think maybe the initialization is incompleted in sysInit and do some job can not be done in romInit
for booting by ppcbug.
  Best Regards
zhuangjian
2009-02-03
发件人:Matt Rippa
发送日期:2009-02-03 08:11:11
收件人:zhuangjian
抄送:tech-talk
主题:Re: boot vxworks from ppcbug in mv5100
Hi zhuangjian -
Maybe someone else has tried this? I'm not sure you can boot
VxWorks in this way --at least not without some work on the image.
If bank A is not physically damaged, it may be easier to
re-flash the bootrom . This page has helped in the past,
assuming you have a known good bootrom.mv5100:
http://www.bio.aps.anl.gov/~dgore/beamline/EPICS/VME.html
-Matt
zhuangjian wrote:
> hello,everyone
>    I have a mv5100 board with some problem in flash bank A. So, I want to boot vxworks 5.4 from ppcbug directly without flush
> vxworks bootrom into flash. Now, I find some problem in memeory initialization progress. The program is flying.
>    So, who can give me some suggestions?
>    Best wishes
> zhuangjian
> 2009-02-02
Re: boot vxworks from ppcbug in mv5100 Andrew Johnson
boot vxworks from ppcbug in mv5100 zhuangjian
Re: boot vxworks from ppcbug in mv5100 Matt Rippa
Prev: Re: boot vxworks from ppcbug in mv5100 Matt Rippa
Next: Re: wrong timestamps in monitors Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: boot vxworks from ppcbug in mv5100 Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
