1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CALC record monitors
Date: Tue, 03 Feb 2009 10:20:06 -0500
Hi:
I ran into a problem with not getting the expected CA monitors
from a calc record.
It's a simple calc record meant to count whenever it's processed.
To reset the counter, we write 0 to its VAL field:
record (calc, "XYZ_Cnt")
    field (INPA, "XYZ_Cnt")
    field (CALC, "A+1")
Many times, that works OK. But at least with R3.14.8.2,
it omits the monitor for the initial count from 0 to one
after a reset.
Example 'camonitor' output:
# After IOC start, the record is invalid
XYZ_Cnt                        <undefined> 0 UDF INVALID
# After "caput XYZ_Cnt.PROC 1", it counts up to 1
XYZ_Cnt                        2009-02-03 09:33:01.570935 1
# With "caput XYZ_Cnt.VAL 0" it resets to 0 and sends a monitor for that
XYZ_Cnt                        2009-02-03 09:33:01.570935 0
# BUT: When checking dbpr on the IOC, I finds MLST: 1,
# so the record thinks that the monitor sent out was 1,
# even though I just got the value 0?!
# When I issue another "caput XYZ_Cnt.PROC 1", dbpr will
# show VAL:1, so the record counts OK, but it fails
# to send a monitor, which makes sense with MLST: 1.
# After another "caput XYZ_Cnt.PROC 1", it counts again,
# and this time also sends a monitor
XYZ_Cnt                        2009-02-03 09:33:23.019859 2
In general, simply performing a "caput XYZ_Cnt.VAL 0"
seems to leave the calc's MLST where it was.
I assume that's because Channel Access & the database code
directly update the VAL field without triggering the CALC's
process routine.
The "fix" for me is to set MDEL=-1, always getting monitors
even though the record's idea of the last value, MLST,
is wrong.
-Kay
Re: CALC record monitors Andrew Johnson
Prev: Re: wrong timestamps in monitors Benjamin Franksen
Next: MaxP PCI motor interface Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS Codeathon 2009 at Brookhaven Andrew Johnson
Next: Re: CALC record monitors Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
