1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: wrong timestamps in monitors
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Tue, 3 Feb 2009 06:51:26 -1000 (HST)
On Tue, 3 Feb 2009, Benjamin Franksen wrote:
Our idea for an efficient implementation is based on the observation
that in a typical EPICS database there are only very few fields per
record that actually receive dbPuts (or get updated directly from
within base). Only for these fields is it necessary to provide
storage for the time of the last update. This storage will be
allocated on demand; each record must maintain a (typically very
short) list of (field index, timestamp) pairs; let us call it the
'field update list' or short 'update list'. When reading the
timestamp for a field, first search the update list and use the
contained stamp if one is found, otherwise use the TIME field of the
record.
How does that implement (b) ? If a field is never updated,
shouldn't that field then report the time when iocInit() was
executed?
Ah, a good objection. It looks as if we need to distinguish between
fields that have
 i)   never been changed (timestamp = iocInit time)
only if PINI=Yes?
Surely not. Every field gets initialized at startup. PINI should be treated
like all other processing.
I use TIME=0000 (etc., not sure about exact format) in trouble shooting
new stuff a lot, and I'd like to have it kept as a feature for records
when PINI is NO. It's much easier to find all the zeros than the UDF
field.
You can see that as a feature request, and if people disagree, then,
obviously not. But for me it's a "nice to have".
Aloha,
Maren
wrong timestamps in monitors Benjamin Franksen
Re: wrong timestamps in monitors Benjamin Franksen
Re: wrong timestamps in monitors Maren Purves
Prev: Re: CALC record monitors Andrew Johnson
Next: SNCSEQ Path Problems Pawel Kowalski - BiRa Systems Inc.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: wrong timestamps in monitors Benjamin Franksen
Next: Re: wrong timestamps in monitors Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
