Pawel, You need to build the sequencer, and specify the path to its top-level
directory in your application's configure/RELEASE file, as the value of SNCSEQ.
If you're using EPICS 3.14.10, make sure you get version 2.0.12.
http://epics.web.psi.ch/software/sequencer/
Pawel Kowalski - BiRa Systems Inc. wrote:
Hello, I am totally new to epics and quite new to linux. It looks like after
much trouble I have finally been able to compile epics base on cygwin
running under windows xp. I am now trying to get the sample application
running from the "Epics Application Developer's Guide" in section 2. I have
made it down to section 2.2.4 where it asks me to set SNCSEQ. The problem is
I don't really know what to set this to. When I leave this commented out the
application compiles but doesn't run. I see that there is a sncExample.st
file under "myexampleApp/src" that makebaseApp.pl made. When I set this
variable to that location (epics_apps/myexampleApp) and uncomment it the
program fails to compile, the output is:
Pawel Kowalski@SKLED /epics_apps
$ make
make -C ./configure install
make[1]: Entering directory `/epics_apps/configure'
perl /epics/base/bin/cygwin-x86/convertRelease.pl checkRelease make -C
O.cygwin-x86 -f ../Makefile TOP=../.. T_A=cygwin-x86 install
make[2]: Entering directory `/epics_apps/configure/O.cygwin-x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/epics_apps/configure/O.cygwin-x86'
make[1]: Leaving directory `/epics_apps/configure'
make -C ./myexampleApp install
make[1]: Entering directory `/epics_apps/myexampleApp'
make -C ./src install
make[2]: Entering directory `/epics_apps/myexampleApp/src'
make -C O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86 install
make[3]: Entering directory `/epics_apps/myexampleApp/src/O.cygwin-x86'
make[3]: *** No rule to make target `sncExample.o', needed by
`myexampleSupport.
dll'. Stop.
make[3]: Leaving directory `/epics_apps/myexampleApp/src/O.cygwin-x86'
make[2]: *** [install.cygwin-x86] Error 2
make[2]: Leaving directory `/epics_apps/myexampleApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/epics_apps/myexampleApp'
make: *** [myexampleApp.install] Error 2
Any help would be greatly appreciated.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
- SNCSEQ Path Problem Pawel Kowalski - BiRa Systems Inc.
Multiple power supplies on one IOC Bertrand H.J. Biritz
Changes to PCAS in 3.14 Elliott Wolin
<2009>
2025
2026
<2009>
2025
2026
