1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with subArray - unnecessary memory allocation
To: Noboru Yamamoto <[email protected]>
Cc: [email protected]
Date: Wed, 04 Feb 2009 13:48:22 +0100
Noboru Yamamoto wrote:
We encountered same problem when we building KEKB control system.
Our solution is to modify EPICS base and provide API to access a part of
source waveform. And also we created a record named CompactSubArrayRecord, which uses API above and copy data just it needs.
Unfortunately this mechanism works only for DB-link but not for CA-link.
(We will need to extend CA protocol to access a part of waveform data,say channel name like "myWaveFormRecord[10:20]")
And also you need to change source code of base.
We have been using this version of modified base in KEKB and J-PARC and
encounters no problem caused by this change.
I found your earlier posts on tech-talk also. Thank you very much.
I just looked at the memory consumption of the softIoc running my subArrays and finally decided that using a few MB of a reasonable sized Linux-Machine is not enough reason to get deeper into this and even patch base for this single purpose. I can live with the higher memory footprint.
I just stumbled over an unnecessarily high (at first glance) memory usage.
But if one runs into this problem on an IOC with just a few MB of memory, your solution seems just perfect to solve this issue.
Thanks again,
Thomas
Thomas Birke
Operation Controls
Elektronenspeicherring BESSY II
Albert-Einstein-Str. 15, 12489 Berlin
Fon +49 30 6392 4934
Fax +49 30 6392 4859
Helmholtz-Zentrum Berlin für Materialien und Energie GmbH Glienicker Straße 100, 14109 Berlin Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph Stellvertretende Vorsitzende: Dr. Jutta Koch-Unterseher Geschäftsführer: Prof. Dr. Anke Rita Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer Sitz der Gesellschaft: Berlin Handelsregister: AG Charlottenburg, 89 HRB 5583 Information: Durch die Fusion mit dem ehemaligen Hahn-Meitner-Institut (HMI) ist BESSY nun Teil des neuen Helmholtz-Zentrum Berlin für Materialien und Energie (HZB). By the merger with the former Hahn-Meitner-Institut (HMI), BESSY became part of the new Helmholtz-Zentrum Berlin für Materialien und Energie (HZB). Disclaimer automatically attached by the E-Mail Security Appliance mail0.bessy.de 02/04/09 at Helmholtz-Zentrum Berlin GmbH.
Problem with subArray - unnecessary memory allocation Thomas Birke
Re: Problem with subArray - unnecessary memory allocation Thomas Birke
Re: Problem with subArray - unnecessary memory allocation Noboru Yamamoto
Prev: Re: Problem with subArray - unnecessary memory allocation Noboru Yamamoto
Next: Incompatibility between alh and excas in 3.14.10 Elliott Wolin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
