Channel Access bindings seems to be one of those areas which some people,
including myself, just can't leave alone. At Diamond we've been working
on our own version, which I'd like to publicise now.
At http://controls.diamond.ac.uk/downloads/python/cothread you can
download the latest version of our "cothread" library and see the detailed
documentation online. I'll explain the name and the logic in a moment --
the story is not simple!
The core functionality is, IMHO, nice and smooth -- in fact, it's so
simple you'll ask why am I making such a fuss about it. Here's some
sample code:
import cothread
from cothread.catools import * # Imports caget, caput, camonitor
print caget('TESTPV') # Read from PV and print
caput('TESTPV', 123) # Write to PV
def monitor(value):
print 'got', value
camonitor('TESTPV', monitor)
cothread.Sleep(10) # Let monitor tick away for 10 seconds
The essential point is (and you'll have to read the documentation, online
at http://controls.diamond.ac.uk/downloads/python/cothread/1-12/docs for
details) that the easy case is simple (as shown above), but actually
you'll find support for *all* relevant channel access features through
this interface.
For example, if you want a timestamp, and you want the data in floating
point that's easy enough:
x = caget('TESTPV', format=FORMAT_TIME, datatype=float)
print x, x.timestamp
# Ok, raw seconds is unfriendly. Use this incanation for pretty print:
from datetime import datetime
print datetime.fromtimestamp(x.timestamp)
I've collapsed the myriad of possible channel access formats into three
format choices (data only, data with timestamps and severity, data with
all control fields), together with an orthogonal choice of datatype. This
seems to provide the cleanest user interface, and is fully compatible with
what channel client access actually provides.
There are essential dependencies on the numpy and ctypes libraries -- all
array data is returned using numpy arrays, and indeed numpy's built in
conversion functionality is incredibly useful when converting between
channel access dbr and Python data formats. There is also a dependency on
the greenlet Python library: this provides the underlying mechanism
required to implement cothreads. Finally, there is (just realised this) a
hard-wired path to libca.so in cadef.py -- you'll need to edit this!
Now to the heart of the matter: why "cothread"?
A complete channel access binding library cannot dodge the problem of
concurrency. First and most important, camonitor events can arrive, in
principle, at any time, and some mechanism needs to be provided to support
this. Also it is frequently a helpful optimisation to perform multiple
channel access operations in parallel to reduce delays -- for example
xl = caget(['PV%d' % i for i in range(100)])
fetches a list of 100 values with all 100 connections and fetches running
concurrently. This can run 100 times as fast as doing the fetches
sequentially.
So the obvious answer is to use threads ... but there are some snags.
Whether the snags are large enough to justify the effort that's gone into
this library is open to question, but the library exists and works quite
well within its limitations.
The problems with using threads are:
1. Synchronisation. This is the biggie, and everybody gets this wrong.
We *still* don't have a programming model that prevents us from making
embarassing synchronisation errors.
2. Python threads are ... slightly feeble. The problem with Python
threads is the "Global Interpreter Lock" -- this monster synchronisation
point ensures that while Python is executing Python code there is actually
only one thread active. This means that C library calls can run
concurrently, but Python code gains no benefit from multiple processors.
The interpreter lock protects the Python interpreter from
synchronisation errors, but doesn't help individual Python applications,
as switching between Python threads occurs at random, as far as the
application is concerned.
3. Threads are not cheap. The caget([...]) call above spawns 100
concurrent "cothreads" -- there's no way this would be affordable with
real threads. Of course there are other ways of doing this task, but the
concurrent cothread solution is nice to write and well behaved, and the
mechanism is now available for other applications.
So what *is* a cothread? You could call it a "cooperative thread", and
the underlying concept is called a "coroutine". The primitive notion of
coroutine is very basic and has been around for quite a long time. The
greenlet library which the cothread library depends on provides just one
function to switch between coroutines:
x = task.switch(y)
This passes the value y to another task's .switch, where it is returned;
when control is explicitly switched back to us we'll receive the value
passed to that switch as the value assigned to x.
This primitive is very low level and actually very error prone to use in
practice (keeping track of just which switches can occur when can become
rather difficult). The cothread library therefore wraps this so that
cothreads behave very like ordinary threads -- except that control is only
transferred between cothreads at well defined points. This has involved
the construction of a cothread scheduler which has become quite
sophisticated.
The primitive cothread operations are:
Spawn() to create a new cothread
Sleep(delay) to suspend calling cothread for delay seconds
event.Wait() wait for event to become signalled
event.Signal() wake up another cothread waiting on an event
In this list only Sleep() and Wait() will result in control being lost to
other cothreads (the complete list includes also Yield() and the catools
functions, which call these primitives in their implementation).
The one big disadvantage of using cothreads is that if any cothread blocks
waiting for input then the entire application will block. It is possible
to spawn a background thread for blocking I/O and communicate with it via
the cothread.ThreadedEventQueue (only the main thread can run cothreads in
the current implementation -- I was reluctant to add a thread local
storage access to every scheduler reference, and there are some
initialisation complexities). Alternatively cothread.select or
cothread.poll can be used to avoid blocking.
The cothread library also comes with Qt and readline bindings: this means
that the interactive interpreter can be used to draw graphs, which can
even update in the background while you type into the interpreter! To
enable the Qt bindings cothread.iqt() must be called, preferably before
importing qt or PyQt4 -- note however that compromises have had to be made
with Qt and there are some quirks, in particular modal windows are a
disaster area.
See the documentation, see if the library works for you, let me know what
you think.
- Problem with cothread-1-12 on MacOSX (Leopard) Juan Carlos Guzman
Diamond Libera EPICS Driver Michael Abbott
Re: EPICS Build without '-ansi' Andrew Johnson
<2009>
2025
2026
Re: Diamond Libera EPICS Driver Michael Abbott
<2009>
2025
2026
