On Wed, 4 Feb 2009, Rod Nussbaumer wrote:
> I have some C code written elsewhere that I want to compile with the
> EPICS build system. The code has quite a bit of C++-style commenting in
> it, and gcc bails with complaints about such commnts, as the standard gcc
> commandline in EPICS includes the '-ansi' option. Is there any way to
> remove the -ansi option for this project only?
We normally override the compiler language setting using the CMPLR variable in
a Makefile, so this switches to using the -traditional flag to gcc (which
actually generated an error for me just now, showing that we don't use it any
more):
CMPLR = TRAD
You can define your own settings as well, like this:
CMPLR = GNU99
CONFORM_CFLAGS_GNU99 = -std=gnu99
Note that the CMPLR setting applies to all files built from this Makefile, but
you can use a target-specific variable to change it when compiling a
particular specific file <name>.c, like this (tested):
<name>.o : CMPLR = GNU99
This will apply that flag for all architecture builds, which is fine if you
only build using gcc architectures, but not much use if you have to support
other compilers as well (but then they have to support that particular
dialect of C anyhow, so maybe this isn't really an issue).
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- EPICS Build without '-ansi' Rod Nussbaumer
- Re: EPICS Build without '-ansi' Michael Abbott
Python Channel Access bindings Michael Abbott
Re: Diamond Libera EPICS Driver Andrew Johnson
<2009>
2025
2026
Diamond Libera EPICS Driver Michael Abbott
<2009>
2025
2026
