1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Firewall configuration?
To: Chris Jacobsen <[email protected]>
Cc: [email protected]
Date: Thu, 05 Feb 2009 22:46:17 +0100
Hm.
Seen from the client machine you will need outgoing access to 5064/TCP (data connection), 5064/UDP outgoing and incoming (name resolution), and 5065/UDP incoming (server beacons). Timeouts are usually caused by the name resolution mechanism not working properly. Can you run wireshark to see if the outgoing name requests and/or the incoming answers are blocked?
Good luck!
Ralph
On 05.02.2009 22:15 Chris Jacobsen wrote:
Hi - I'd like to have a firewall configured on my linux system but when I turn it on then I get a timeout when accessing EPICS variables on a remote system. I thought it would be sufficient to enable TCP and UDP access on ports 5064 and 5065, since I'm running with a "standard" EPICS build on the latest release. Can anyone suggest what else I need to set in a firewall configuration to allow EPICS to work?
Thanks, Chris Jacobsen
Firewall configuration? Chris Jacobsen
Prev: Firewall configuration? Chris Jacobsen
Next: RE: Firewall configuration? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
