Hi Chris,
I had a similar problem with the standard BNL firewall on Windows (Trend
I think?). I think the problem was as follows:
- EPICS sends a multicast message to find the PVs on a port you have
enabled
- The client responds, but because the outgoing message was a multicast
the incoming port was apparently not opened for that server. I proved
this by setting EPICS_CA_ADDR_LIST to specifically include the IP
address of the server, and then it worked. You could try that.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Chris Jacobsen
Sent: Thursday, February 05, 2009 3:15 PM
To: [email protected]
Subject: Firewall configuration?
Hi - I'd like to have a firewall configured on my linux system but
when I turn it on then I get a timeout when accessing EPICS variables
on a remote system. I thought it would be sufficient to enable TCP
and UDP access on ports 5064 and 5065, since I'm running with a
"standard" EPICS build on the latest release. Can anyone suggest what
else I need to set in a firewall configuration to allow EPICS to work?
Thanks, Chris Jacobsen
- Re: Firewall configuration? Chris Jacobsen
- Firewall configuration? Chris Jacobsen
Re: Firewall configuration? Ralph Lange
RE: Firewall configuration? Allison, Stephanie
<2009>
2025
2026
<2009>
2025
2026
