1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Firewall configuration?
To: "Chris Jacobsen" <[email protected]>, <[email protected]>
Date: Thu, 5 Feb 2009 13:51:08 -0800
Hi Chris,
> Hi - I'd like to have a firewall configured on my linux system but
> when I turn it on then I get a timeout when accessing EPICS variables
> on a remote system.  I thought it would be sufficient to enable TCP
> and UDP access on ports 5064 and 5065, since I'm running with a
> "standard" EPICS build on the latest release.  Can anyone
> suggest what else I need to set in a firewall configuration to allow EPICS to work?
This is fine for destination ports but we also enable 1 to 65535 on source ports for the CA TCP connections.
Stephanie Allison
Firewall configuration? Chris Jacobsen
Prev: RE: Firewall configuration? Mark Rivers
Next: Re: Firewall configuration? Chris Jacobsen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Firewall configuration? Chris Jacobsen
Next: problem using the gpib-asyn support Maurizio Montis
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
