i'm tring to understand how to create a new support. i want to have an
ioc that read a string from an IP address.
Into the devXXX.c file i defined the command:
/* Param 0 -- */
{&DSET_SI, GPIBRAWREAD, IB_Q_LOW, 0, 0, 0, 200, 0, 0, 0, 0, 0, 0}
so i can crate a StringIn record for the reading operation.
Into the st.cmd i wrote theese commands:
## Load record instances
dbLoadRecords("db/testLettura.db","P=issio.,R=,L=0,A=0")
drvAsynIPServerPortConfigure("L0","192.168.39.98:9027",10,0,0,0)
but when i start my ioc i've the following problem:
2009/02/06 12:37:46.739 L0 devGpib registerSrqHandler failed
asynManager:getInterruptPvt Driver does not support interrupts on
interface asynInt32
2009/02/06 12:37:47.251 issio.messia read status "L0 readRaw not
implemented " nin 0
2009/02/06 12:37:47.251 issio.messia error.
2009/02/06 12:37:47.353 issio.messia queueRequest failed timeWindow
active
i think that the problem is in the param definition and i tried to
modify it, but i can't understand where my mistake is.
can someone help me?
thanks a lot
Re: Firewall configuration? Chris Jacobsen
"Count Num or Channel" option in MEDM cartesian plot Noboru Yamamoto
<2009>
2025
2026
RE: Firewall configuration? Allison, Stephanie
<2009>
2025
2026
