Hi Brian,
The asyn driver does not have access to the record. The driver only
talks to device support, and the device support talks to the record.
I don't think you can do what you want using standard asyn device
support. But if you wrote your own device support for the mbbo record
(based on the mbbo support in devAsyn/devAsynInt32.c for example) you
could use the asynOctet interface to query the driver for the enum
string values during initRecord, and set those enum string values in the
record.
-----Original Message-----
[mailto:[email protected]] On Behalf Of tieman
Sent: Thursday, February 19, 2009 3:40 PM
To: tech talk
Subject: Asyn driver access to PV fields.
Hi all!
I have a situation where I have an mbbo field that I would like to set
programmatically at run time. Specifically, I would like to set ZSTR,
ONST, etc... to specific values that are read back from hardware in a
device driver at initialization. How can I do this from within an Asyn
driver?
Thanks!
Brian
- Re: Asyn driver access to PV fields. Andrew Johnson
- Re: Asyn driver access to PV fields. Marty Kraimer
- Asyn driver access to PV fields. tieman
<2009>
2025
2026
<2009>
2025
2026
