1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn driver access to PV fields.
Cc: tech talk <[email protected]>
Date: Thu, 19 Feb 2009 17:00:39 -0500
Mark Rivers wrote:
Hi Brian,
The asyn driver does not have access to the record.  The driver only
talks to device support, and the device support talks to the record.
I don't think you can do what you want using standard asyn device
support.  But if you wrote your own device support for the mbbo record
(based on the mbbo support in devAsyn/devAsynInt32.c for example) could use the asynOctet interface to query the driver for the enum
string values during initRecord, and set those enum string values in the
record.
What about adding a new method to asynUInt32Digital?
Then change devAsynUInt32Digital so that it supports the new method.
Also change asynUInt32DigitalBase so that it implements the new method by returning failure. Thus no existing driver will fail.
Marty
RE: Asyn driver access to PV fields. Mark Rivers
Asyn driver access to PV fields. tieman
Prev: Re: Asyn driver access to PV fields. Andrew Johnson
Next: Re: Asyn driver access to PV fields. Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Asyn driver access to PV fields. Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
