Hi Brian,
StreamDevice can do this. Use a combination of @init handler and "%(ZRST)16c"
redirection. See http://epics.web.psi.ch/software/streamdevice/doc/ chapters
"Record Processing" -> "Initialization" and "Format Converters" -> "Types & Fields".
It might be possible that not all client applications get the enums correctly.
If the client is already connected and you reboot the ioc and it starts up with
new enum strings, the client might still use the old enums.
Dirk
tieman wrote:
Hi all!
I have a situation where I have an mbbo field that I would like to set
programmatically at run time. Specifically, I would like to set ZSTR,
ONST, etc... to specific values that are read back from hardware in a
device driver at initialization. How can I do this from within an Asyn
driver?
Thanks!
Brian
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- Asyn driver access to PV fields. tieman
Re: Asyn driver access to PV fields. Marty Kraimer
RE: Asyn driver access to PV fields. Mark Rivers
<2009>
2025
2026
Re: Asyn driver access to PV fields. tieman
Mac OS X and environ Stephen Norum
<2009>
2025
2026
ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
