Hello,
I ran into a missing symbol in EPICS base on Mac OS X. Starting in
Mac OS X 10.5 (Leopard), shared libraries and bundles don't have
direct access to environ (man environ).
Shared libraries and bundles don't have direct access to environ,
which is only available to the loader ld(1) when a complete program
is being linked. The environment routines can still be used, but if
direct access to environ is needed, the _NSGetEnviron() routine,
defined in <crt_externs.h>, can be used to retrieve the address of
environ at runtime.
http://developer.apple.com/documentation/Darwin/Reference/Manpages/man7/environ.7.html
I copied libCom's osdEnv.c to base/src/libCom/osi/os/Darwin and added
the following:
/* Starting in Mac OS X 10.5 (Leopard), shared libraries and
* bundles don't have direct access to environ (man environ).
* Define environ as (*_NSGetEnviron())
#include <crt_externs.h>
#define environ (*_NSGetEnviron())
Everything seems to work fine with this change and it has been
committed to the trunk and R3-14-2_branch by Eric Norum.
Stephen
Re: Asyn driver access to PV fields. tieman
Dynamic Listing of PVs Bruno Coudoin
<2009>
2025
2026
Re: Asyn driver access to PV fields. Dirk Zimoch
<2009>
2025
2026
