Noboru Yamamoto wrote:
> Thanks Tim and Ben,
> Tim Mooney wrote:
>> Noboru,
>> Similar:
>> The sCalcout record (in the synApps calc module) does this.
>> See http://www.aps.anl.gov/bcda/synApps/calc/calc.html
> I will check it, tomorrow.
> Benjamin Franksen wrote:
>> On Tuesday 24 February 2009 07:50, Noboru Yamamoto wrote:
>>> I'm looking for a soft device support for ai which convert string data
>>> from INPUT link to analogue value, like sscanf in C language.
>>> Does anyone have this or similar device support ?
>> Have you looked at StreamDevice?
> If I needed to access HW, I woudl use StreamDevice or asynDriver.
> In this case, we already have device support (and stringin records)
> which takes data from HW. So now our user want convert this string into
> number in EPICS database.
> Does StreamDevice work with stringin record in this way?
At the moment, StreamDevice has no driver support to read input from a PV. But
StreamDevice is quite flexible. Thus it should be possible to add such a driver
layer. However, if anyone has already written an asynOctet support that reads
from PVs StreamDevice can use it right away...
I think, at the moment it is easier to use sCalcout.
Dirk
>> http://epics.web.psi.ch/software/streamdevice/
>> Cheers
>> Ben
> Thank you very much again for your help.
> Regards,
> Noboru
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- soft device for ai record works as sscanf. Noboru Yamamoto
- Re: soft device for ai record works as sscanf. Benjamin Franksen
- Re: soft device for ai record works as sscanf. Noboru Yamamoto
Re: errlogPrintf from iocsh for soft IOCs? Eric Norum
use and utility of permissive record haquin
<2009>
2025
2026
can't output strings array with gensub haquin
<2009>
2025
2026
