1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: use and utility of permissive record
To: [email protected]
Date: Wed, 25 Feb 2009 16:45:17 +0100
Hi all,
I may be interested in using the Permissive record,
but I don't understand everything from the record reference manual
about how to make it processing:
The record manual (Client-server Parameters section of the permissive record) says that when WFLG is ON (th record is ready), the client program must not turn VAL to on. So I wonder what is the normal way of triggering the processing of this record ?
Currently the client will be me behind the IOC shell.
I use release 3.14.9 release, I've read the following from Andrew in the thread :Re: "DISP and permissive record" "It has not been converted to R3.14 to my knowledge, and I'm not aware of anyone who is actually using it. There have been at least a couple more recent records designed for vaguely similar activities such as the APS runControl record and the CAD/CAR/SIR records from Gemini and Observatory Sciences"
Is this still true ?
What are the APS runControl record and the CAD/CAR/SIR records and where can I find them ?
Regards.
begin:vcard
fn:Christophe Haquin
n:Haquin;Christophe
email;internet:[email protected]
tel;work:02 31 45 46 61
x-mozilla-html:FALSE
version:2.1
end:vcard
Re: use and utility of permissive record Emmanuel Mayssat
Prev: Re: soft device for ai record works as sscanf. Dirk Zimoch
Next: Snl strings Gerke, Christian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: can't output strings array with gensub haquin
Next: Re: use and utility of permissive record Emmanuel Mayssat
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
