Thank you Matthieu, for your solution, I've just tried it.
Eric,
In my genSub, I will analyse the bits of a Defect word, and translate
each bit field in a string, then I output an array where the strings are
available for operator display.
Implementation with several mbbi records cannot fulfill all my needs, so
I do the analysis with genSub.
All this to explain I am not concatenating several mesages so your
proposal is not adequate, thanks anyway.
However, don't hesitate if you have any other suggestion of implementation.
Best Regards.
Eric Norum a écrit :
Are you trying to just send and print the concatenated error message
strings?
Perhaps something like this is adequate?
FTVN: CHAR
NOVN: 120
int nleft = precord->novn;
char *np = (char *)precord-:>valn;
int n;
n = epicsSnprintf(np, nleft, "Defect string 1. ");
nleft -= n;
np += n;
n = epicsSnprintf(np, nleft, "Defect string 2. ");
nleft -= n;
np += n;
haquin wrote:
Hi all,
I have configured a gensub record to output a string array but this
doesn't work.
I set the following genSub fields:
FTVN:STRING
NOVN:12
in my process function I do the following:
sprintf ((char*)precord->valn, "Defect String 1");
sprintf ( (char*)(((char**)(precord->valn))+1), "Defect String 2");
When I execute the IOC, the output is the following:
epics> dbgf IOCASTE-TST:ProcessDynamicModbusTable.VALN
DBR_STRING: DefeDefect String 2
the second string has overwritten the first one.
It seems that there only one string
thanks in advance for your help.
begin:vcard
fn:Christophe Haquin
n:Haquin;Christophe
email;internet:[email protected]
tel;work:02 31 45 46 61
x-mozilla-html:FALSE
version:2.1
end:vcard
- can't output strings array with gensub haquin
- Re: can't output strings array with gensub Matthieu Bec
- Re: can't output strings array with gensub Eric Norum
Re: Dynamic Listing of PVs Andrew Johnson
<2009>
2025
2026
use and utility of permissive record haquin
<2009>
2025
2026
