1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: AW: Snl strings
To: "Eric Norum" <[email protected]>
Cc: [email protected]
Date: Thu, 26 Feb 2009 10:54:26 +0100
Thank you Eric,
I needed both modifications:
1) char debus[40];  ==>  string debus;
(which I did not try before)
And
2) sprintf  ==>  strcpy
(which I had tried already)
Christian
-----Ursprüngliche Nachricht-----
Von: Eric Norum [mailto:[email protected]]
Gesendet: Mittwoch, 25. Februar 2009 17:18
An: Gerke, Christian
Betreff: Re: Snl strings
Declare the variable as a string:
string currentState;
assign currentState to "{P}ClockScanStateSI";
             strcpy(currentState, "Scan P0 phase");
             pvPut(currentState);
On Feb 25, 2009, at 10:07 AM, Gerke, Christian wrote:
> Hi
> For EPICS 3.13 and SNL 1.9.5 how do I send a string from a snl program
> to a stringin-record?
> I tried:
> char debus[40];
> assign debus to "KS2:SNL:KUE:DEBUS_stringin";
> sprintf(debus,"HDTemp init");
> pvPut(debus);
> As a result the stringin VAL field contains "72" (the ascii code of
> "H",
> the frist string character) which is not quite what I want.
> Is there a problem with strings (character arrays) in snl or the
> stringin record?
> Or is there something wrong with my approach?
> Christian
> ___________________________________________________________________
> Christian Gerke
> Deutsches Elektronen Synchrotron DESY
> Mitarbeiter der Gruppe MKS2
> http://www-mks2.desy.de
> Tel +49 40 8998-4028
> Fax +49 40 8994-4028
> [email protected]
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: AW: Snl strings Eric Norum
Snl strings Gerke, Christian
Re: Snl strings Eric Norum
Prev: Re: use and utility of permissive record Emmanuel Mayssat
Next: Re: AW: Snl strings Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Snl strings Eric Norum
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
