1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Record Initialization
To: "EPICS Techtalk" <[email protected]>
Date: Thu, 26 Feb 2009 21:53:22 -0800
I am trying to do something very simple and not succeeding.
I have two records:
record( longout, "$(P):LO:FIL:TVAL"){
  field( DESC, "timeout in sec")
#  field( OUT,  "$(P):$(R):LO:TIME:LEFT PP")
  field( OUT,  "$(P):$(R):CALC:TIME:LEFT:1PSEC")
  field( VAL,  "3600")
  field( PINI, "YES")
record( calc, "$(P):$(R):CALC:TIME:LEFT:1PSEC"){
  field( DESC, "increment 1/sec")
  field( SCAN, "1 second")
  field( CALC, "C?D:B?(A?A-1:0):A")
  field( INPA, "$(P):$(R):CALC:TIME:LEFT:1PSEC.VAL NPP")
  field( INPB, "$(P):$(R):BO:TIME:LEFT:ENABLE.VAL NPP")
  field( INPC, "$(P):$(R):CALC:TIME:LEFT:RESET.VAL NPP")
  field( INPD, "$(P):$(R):LO:TIME:LEFT.VAL NPP")
  field( FLNK, "$(P):$(R):GS:TIME:LEFT")
When my test soft ioc goes through the init phase, I expected that the first of the two records would process and write the value 3600 to the VAL field of the second record, but that does not happen.  If my second record is longout then the value gets written to it.  When I process the first record with caput by writing 1 to its PROC field, then the value is written to the calc record.  Why does it not work at iocInit time?  Is there some simple way of transferring the value from the first record to the calc record at iocInit time?  Any suggestions will be appreciated.
Zen
Re: Record Initialization Dirk Zimoch
Prev: Re: caget with an array of space-containing strings Matthieu Bec
Next: Re: caget with an array of space-containing strings Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget with an array of space-containing strings Dirk Zimoch
Next: Re: Record Initialization Dirk Zimoch
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
