1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget with an array of space-containing strings
To: Carl Schumann <[email protected]>
Cc: [email protected]
Date: Fri, 27 Feb 2009 09:35:20 +0100
Hi Carl,
You can modify caget to put quotes around strings (and escape quotes in the string -- and escape escape characters).
Dirk
Carl Schumann wrote:
I am using the command-line caget with an array of space-containing strings. Apparently caget uses spaces to separate array elements. A space separator causes some difficultly in this case because the elements themselves contains spaces. For example, ...
clx39:~ $ caget -# 1 ADC00.RNGS
ADC00.RNGS                     50, 10k: -10->0
clx39:~ $ caget ADC00.RNGS
ADC00.RNGS 9 50, 10k: -10->0 50, 10k: +-5 50, 10k: 0->10 50: -6->0, 10k: -5->0 50: +-3, 10k: +-2.5 50, 10k: 0->5 50: -5->0, 10k: -2->0 50: +-2.5, 10k: +-1 50: 0->5, 10k: 0->2
clx39:~ $
One can ask for specific elements as I have done, but that is a little bit inconvenient. Any suggestions?
Carl Schumann
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
caget with an array of space-containing strings Carl Schumann
Prev: Record Initialization Szalata, Zenon M.
Next: Survey by ATOS on EPICS Applications Di Maio Franck
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget with an array of space-containing strings Matthieu Bec
Next: Record Initialization Szalata, Zenon M.
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
