1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS drivers or an EPICS interface to lantronix Embedded Deviceserver communicating over TCP/IP
To: "Sandeep Babel" <[email protected]>, <[email protected]>
Date: Fri, 27 Feb 2009 12:52:33 -0600
You create an asyn port server talking to that IP address and port with
the drvAsynIpPortConfigure command in your startup script.  For example:
drvAsynIPPortConfigure("LAN1","xxx.xxx.xxx.xxx:10001")
where LAN1 is the name of the asyn port you are creating, and xxx is the
IP address or name of your device.
That will let you communicate with the device using the asynOctet
interface.
At the next layer up you can use the stream device support, or simply an
asyn record, etc.  Do you talk to it in ASCII strings?
-----Original Message-----
[mailto:[email protected]] On Behalf Of Sandeep Babel
Sent: Friday, February 27, 2009 12:14 PM
To: [email protected]
Subject: EPICS drivers or an EPICS interface to lantronix Embedded
Hello Everyone,
We have developed a custom power supply controller with a Lantronix
XPORT embedded device server on it. The Lantronix XPORT is an Ethernet
to Serial chip. It is communicating with my LabView program over TCP/IP.
The port number on the Lantronix is 10001. How do I interface this to an
existing EPICS system ? What would I need to setup ? I am a newbie when
it comes to EPICS.
Thanks for all the suggestions.
Sandeep
EPICS drivers or an EPICS interface to lantronix Embedded Device server communicating over TCP/IP Sandeep Babel
Prev: Basic misunderstanding concerning record chaining in sub records Elliott Wolin
Next: Useless error messages in EPICS Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS drivers or an EPICS interface to lantronix Embedded Device server communicating over TCP/IP Sandeep Babel
Next: Basic misunderstanding concerning record chaining in sub records Elliott Wolin
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
