1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Variable size frame
To: <[email protected]>
Cc: [email protected]
Date: Wed, 4 Mar 2009 19:20:50 -0600
Those are good questions.  I have a more fundamental problem in my application, which is that it is not really a 1-D array, it is 2-D or 3-D.  CA has no mechanism for that, so I need to send the size separately anyway.
Sent: Wed 3/4/2009 3:54 PM
To: Mark Rivers
Cc: Jeff Hill; [email protected]
Le mercredi 04 mars 2009 à 14:56 -0600, Mark Rivers a écrit :
> I don't know about the CAS server, but in an IOC I post the array
>  data first and then the size.  The client waits for a monitor on
>  the size, and then does a ca_get on the array.  Obviously this is
>  not foolproof, depending on the rates of new data and latencies but
>  in practice it works well for me.
Hum, this works but its not really straightforward.
So it seems that I am not alone with this issue. Is there a plan to
enhance the protocol to make it easy.
For example, could we use the parameter 1 or 2 of the message header for
storing the payload size. Better, why do we have to send the max
possible array size in the first place and not just the actual payload
size.
Bruno.
Variable size frame Bruno Coudoin
RE: Variable size frame Jeff Hill
RE: Variable size frame Bruno Coudoin
RE: Variable size frame Mark Rivers
Prev: RE: Variable size frame Bruno Coudoin
Next: Re-wrap CaChannel based on PythonCA Wang Xiaoqiang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: New Software Engineer Position at NSCL Eric Berryman
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
