Dirk Zimoch wrote:
There was a mistake in my previous mail. You must specify the field in
the redirections (usually VAL).
in "%*/Measure\(PPM\):/%f"
"%*/Sample flow\(CC\):/%(\$1:FLOW.VAL)f"
"%*/Scale:/%(\$1:SCALE.VAL)s"
"%*/System status:/%(\$1:STATUS.VAL)s";
Dirk
Thanks for your help. I do now have a workable solution for this
application. It turns out that the application actually does not require
the use of regular expressions.
However, I am still confused about the syntax used to extract data
matching a regex, and especially where there are multiple components to
be extracted.
In the example protocol file, there is an entry like:
in "%.1/<TITLE>(.+)<\/TITLE>/";
As I understand it, the notation "%.1" says to use the data matched by
the first parenthesized component (ie the TITLE element data).
Logically, it follows that one could match a second parenthesized regex
component, and assign the matching data to a specified record field. Is
this true, and if so, what notation would be used?
An example of this, using HTML again, might be:
<FONT color="black" size="6">
One can devise a regex that matches the two quoted values of the
attributes, 'color' and 'size'; something like
/<FONT\s+color="(.+)"\s+size="(.+)">/
which contains two parenthesized parts of the regular expression, and
which I might like to assign to separate records. Can this be done, and
if so, what notation would be required?
Thanks.
--- rod.
- Re: Help with streamDevice parsing HTML Dirk Zimoch
- Help with streamDevice parsing HTML Rod Nussbaumer
<2009>
2025
2026
<2009>
2025
2026
