1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS for USB devices
To: "Mehta, Pratik" <[email protected]>, <[email protected]>
Date: Sun, 8 Mar 2009 14:17:49 -0400
While installing epics base on ubuntu linux I got the following error while running make
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE   -m32     -g -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs !
 -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/default/epicsReadline.c
../../../src/libCom/osi/os/default/epicsReadline.c:76:31: error: readline/readline.h: No such file or directory
../../../src/libCom/osi/os/default/epicsReadline.c:77:30: error: readline/history.h: No such file or directory
../../../src/libCom/osi/os/default/epicsReadline.c: In function ?epicsReadlineBegin?:
../../../src/libCom/osi/os/default/epicsReadline.c:101: warning: implicit declaration of function ?stifle_history?
../../../src/libCom/osi/os/default/epicsReadline.c:102: warning: implicit declaration of function ?rl_bind_key?
../../../src/libCom/osi/os/default/epicsReadline.c:102: error: ?rl_insert? undeclared (first use in this function)
../../../src/libCom/osi/os/default/epicsReadline.c:102: error: (Each undeclared identifier is reported only once
../../../src/libCom/osi/os/default/epicsReadline.c:102: error: for each function it appears in.)
../../../src/libCom/osi/os/default/epicsReadline.c: In function ?epicsReadline?:
../../../src/libCom/osi/os/default/epicsReadline.c:124: warning: implicit declaration of function ?readline?
../../../src/libCom/osi/os/default/epicsReadline.c:124: warning: assignment makes pointer from integer without a cast
../../../src/libCom/osi/os/default/epicsReadline.c:162: warning: implicit declaration of function ?add_history?
make[3]: *** [epicsReadline.o] Error 1
make[3]: Leaving directory `/home/pratik/epics/base-3.14.10/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/pratik/epics/base-3.14.10/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/pratik/epics/base-3.14.10/src'
make: *** [src.install] Error 2
I guess some required packages may be missing,
Can anyone tell me which ?
Thank you,
Confused Pratik
Re: EPICS for USB devices Pete Jemian
EPICS for USB devices Mehta, Pratik
Prev: synApps 5.4 release Tim Mooney
Next: Re: EPICS for USB devices Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS for USB devices Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
