1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS for USB devices
To: "Mehta, Pratik" <[email protected]>
Cc: [email protected]
Date: Sun, 08 Mar 2009 13:40:12 -0500
aptitude install libreadline-dev
(USB device support is not particularly relevant to this question)
Mehta, Pratik wrote:
While installing epics base on ubuntu linux I got the following error while running make
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE   -m32     -g -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDef!
s -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/epicsReadline.c
../../../src/libCom/osi/os/default/epicsReadline.c:76:31: error: readline/readline.h: No such file or directory
../../../src/libCom/osi/os/default/epicsReadline.c:77:30: error: readline/history.h: No such file or directory
../../../src/libCom/osi/os/default/epicsReadline.c: In function ‘epicsReadlineBegin’:
../../../src/libCom/osi/os/default/epicsReadline.c:101: warning: implicit declaration of function ‘stifle_history’
../../../src/libCom/osi/os/default/epicsReadline.c:102: warning: implicit declaration of function ‘rl_bind_key’
../../../src/libCom/osi/os/default/epicsReadline.c:102: error: ‘rl_insert’ undeclared (first use in this function)
../../../src/libCom/osi/os/default/epicsReadline.c:102: error: (Each undeclared identifier is reported only once
../../../src/libCom/osi/os/default/epicsReadline.c:102: error: for each function it appears in.)
../../../src/libCom/osi/os/default/epicsReadline.c: In function ‘epicsReadline’:
../../../src/libCom/osi/os/default/epicsReadline.c:124: warning: implicit declaration of function ‘readline’
../../../src/libCom/osi/os/default/epicsReadline.c:124: warning: assignment makes pointer from integer without a cast
../../../src/libCom/osi/os/default/epicsReadline.c:162: warning: implicit declaration of function ‘add_history’
make[3]: *** [epicsReadline.o] Error 1
make[3]: Leaving directory `/home/pratik/epics/base-3.14.10/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/pratik/epics/base-3.14.10/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/pratik/epics/base-3.14.10/src'
make: *** [src.install] Error 2
I guess some required packages may be missing,
Can anyone tell me which ?
Thank you,
Confused Pratik
 Pete R. Jemian, Ph.D.                <[email protected]>
 Beam line Controls and Data Acquisition, Group Leader
 Advanced Photon Source,   Argonne National Laboratory
 Argonne, IL  60439                   630 - 252 - 3189
    Education is the one thing for which people
       are willing to pay yet not receive.
EPICS for USB devices Mehta, Pratik
Prev: EPICS for USB devices Mehta, Pratik
Next: FW: edm version 1-11-1zl and fedora 10 Dropp, Christopher
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: How to get value of stringin input link in an aSub record? Elliott Wolin
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
