1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Looking for feedback on what epics users require
To: "Pawel Kowalski - BiRa Systems Inc." <[email protected]>
Cc: [email protected]
Date: Tue, 10 Mar 2009 11:56:50 -0500
The deployment scenario for these power supplies will likely factor into any given customer's requirements. If there are only a few supplies being used, then as Tim Mooney pointed out, the simplest integration technique is to provide a turn-key IOC. But as Ernest pointed out, there will inevitably be many custom tweaks desired for the turn-key IOC config, so much of the configuration (and possibly code) needs to be exposed.
If there will be hundreds of power supplies being used, then things get a bit more complicated. If each supply has an IOC, then each controlling Channel Access client will have to make hundreds of TCP connections. This can be managed through an EPICS PV Gateway, but the feasibility depends on a customers network layout, and whether or not they want to introduce PV Gateways into their system.
Probably the most flexible approach is to provide EPICS device support and a template of EPICS records that can control your supply. In the case of hundreds of power supplies, for example, the customer could put your UDP traffic on a private subnet, and have just a couple of IOCs running all of the supplies. Then Channel Access clients could access all the supplies with just a couple TCP connections (on a separate subnet). This approach has the added advantage of not having to package up an entire IOC (and reduce your exposure to possible bugs that arise in IOC Core).
   just some thoughts - there is lots to evaluate
         Claude
Pawel Kowalski - BiRa Systems Inc. wrote:
Hello,
My company is researching providing an epics IOC with some of our power supplies. I would like to get some feedback from the epics community on what exactly would be required. First let me start off by saying that epics is still a new area for me so hopefully these questions aren't dumb, we are still in the early research stages on this. What we would like to do is provide a system with each device that will host an EPICS IOC. This will be a vxWorks based system running epics base 3.14. This system will communicate with our device using ethernet and convert standard UDP commands that our devices work on to process variables. So for example our clients would now have a process variable they could use to monitor or set the voltage of a power supply (IE: powersys:voltage). For the client side we would like to develop a LabVIEW interface, we would most likely not be developing a custom C/C++ application for the client. Would this be adequate for most epics users or would more be required to integrate this into an existing epics network? Would people use the LabVIEW client we develop or do most labs use their own custom software to control/monitor epics enabled equipment? Any feedback from the community would be greatly appreciated, thank you.
Looking for feedback on what epics users require Pawel Kowalski - BiRa Systems Inc.
Prev: RE: Looking for feedback on what epics users require Dalesio, Leo
Next: Two EDM questions Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Looking for feedback on what epics users require Tim Mooney
Next: Re: Looking for feedback on what epics users require Ralph Lange
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
