1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: weird behaviour of SNL test program running on Soft IOC on LINUX
Cc: EPICS tech-talk <[email protected]>, Sergey Stepanov <[email protected]>
Date: Mon, 16 Mar 2009 19:21:11 -0400
On 3/16/09 7:06 PM, Mark Rivers wrote:
> Sergey,
> I think it is important to get to the bottom of this. You have a
> workaround, but I don't think you should need to modify your SNL code
> when moving it from vxWorks to Linux. I have definitely not needed to
> do that in the past, and Lewis did not find a problem on the Mac.
Hi, Mark.
I should probably clarify that it's true I couldn't find a problem, but
I only guessed at what "{dev}StrCmd" and "{dev}StrRsp" did (since this
information was not provided) and simulated the behavior.  I didn't
actually try it against a PMAC controller.
Lewis
weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
RE: weird behaviour of SNL test program running on Soft IOC on LINUX Mark Rivers
Re: weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
Re: weird behaviour of SNL test program running on Soft IOC on LINUX J. Lewis Muir
Re: weird behaviour of SNL test program running on Soft IOC on LINUX Pete Jemian
Re: weird behaviour of SNL test program running on Soft IOC on LINUX Sergey Stepanov
Prev: RE: weird behaviour of SNL test program running on Soft IOC on LINUX Mark Rivers
Next: Re: Help building EPICS 3.14.9 for RTEMS Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
