1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building Epics 3.14.10 on Linux
To: [email protected]
Date: Wed, 18 Mar 2009 12:39:57 -0500
Hi Sue,
On Wednesday 18 March 2009 11:39:19 Sue Witherspoon wrote:
>    I am now building EPICS 3.14.10 on linux. The build goes fine until I
> get to cap5 documentation...
>  I'm using perl 5.8.2
I suspect that's the problem, the podchecker and pod2html programs that come
with Perl 5.8.2 (which is now over 5 years old) are not compatible with the
options I'm using.  Since I think this is the very last thing that normally
gets built in Base, you could just ignore the failure, or comment out the
HTMLS= line from the cap5/Makefile to prevent it from happening again.
That file is available on the EPICS website from the R3.14.10 page, or if you
were to build the same copy of Base on an architecture with a later version
of Perl *before* you build for RHEL-4 then I guess it wouldn't need to try
and build it there as well.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Building Epics 3.14.10 on Linux Sue Witherspoon
Prev: Building Epics 3.14.10 on Linux Sue Witherspoon
Next: Re: Starting multiple SNL programs Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: epics GUIs (update) Emmanuel Mayssat
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
