1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Starting multiple SNL programs
To: "Andrew C. Starritt" <[email protected]>
Cc: "EPICS Tech Talk \([email protected]\)" <[email protected]>
Date: Wed, 18 Mar 2009 11:33:32 -0700
On Wed, 2009-03-18 at 11:42 +1100, Andrew C. Starritt wrote:
> Hi all,
> On a couple of IOCs, in the st.cmd file I start a number (7 or 9) SNL
> programs (well actually each IOC it is the same SNL program – with
> option +r
> and parameterised).
> Sometimes one or more random-ish instance fails to connect to
> all the PVs and essentially hangs. If I seqStop and restart the
> hung sequence program it runs as expected okay.
In your initialization state, you should check for PV connections:
ss turnOnOffStateSet {
  state turnOnOffInitializationState {
    entry{
      seqLog("--> turnOnOffInitializationState\n");
      p_deviceName=macValueGet("deviceName");
      seqLog("deviceName=%s\n", p_deviceName);
    when (pvConnectCount() == pvChannelCount()) {
      seqLog("All channels connected\n");
      delay(5);
      seqLog("Reseting communication\n");
    } state resetState
    exit {
      seqLog("<-- initializationState\n");
      /* Buttons are intialized */
      resetRqstdBO=0;pvPut(resetRqstdBO);
      turnOffRqstdBO=0;pvPut(turnOffRqstdBO);
      stndbyRqstdBO=0;pvPut(stndbyRqstdBO);
      highVltgOnRqstdBO=0;pvPut(highVltgOnRqstdBO);
> I have some questions which I hope can get help with.
> The output from seqShow is:
>     Program Name         Thread ID  Thread Name          SS Name
>     sncControl_Selection 0x32a75a0  sncControl_Selection cycle_magnets
>     sncControl_Selection 0x32a2d70  sncControl_Selection cycle_magnets
>     sncControl_Selection 0x32a4580  sncControl_Selection cycle_magnets
>     sncControl_Selection 0x32a5d90  sncControl_Selection cycle_magnets
>     sncControl_Selection 0x32aa5c0  sncControl_Selection cycle_magnets
>     sncControl_Selection 0x32abfe0  sncControl_Selection cycle_magnets
>     sncControl_Selection 0x32a8a30  sncControl_Selection cycle_magnets
> Is there an easy way to tell which instance is which?
That's an interesting question...
I am not sure you can do this through seqShow.
You can do this with the log file (seqLog) but it may be a little
tedious.
> Can I some how parameterise the program name, thread name or SS Name?
> I tried:
>    program sncControl_Selection{NAME}
> and
>    ss cycle_magnets{NAME}
> in the .stt file but neither would even compile.
In stt file:
program snovaTurnOnOff ("deviceName=(null)")
In ioc startup file:
seq snovaTurnOnOff,"deviceName=${SNOVA_DEVN},logfile=
${LOG_DIR}/${SNOVA_DEVN}-snovaTurnOnOff.log,debug=1"
> I also observed that the initial hang-up can is avoided by adding some
> sort of delay between the seq calls, e.g.:
> seq (sncControl_Selection,"NAME=SR03ID01, ILK_NAME=SR03II01")
> dbl * > /tmp/xx
> seq (sncControl_Selection,"NAME=SR04ID01, ILK_NAME=SR04II01")
> dbl * > /tmp/xx
> seq (sncControl_Selection,"NAME=SR05ID01, ILK_NAME=SR05II01")
> dbl * > /tmp/xx
> I have seen this on both epics base 3.14.8.2 with seq-2.0.11 on 4 year
> old
> redhawk Linux system and using epics base 3.14.9 with seq-2.0.11 on a
> newish
> CentOs 5.1 system. Any thoughts as to what is happening?
> If the only solution is a small delay, is there a standard IOC shell
> sleep
> command I could use instead?
In iocsh Try:
help
help epicsThreadSleep
epicsThreadSleep(5)
> Regards
> Andy
> Andrew Starritt, Principal Controls Engineer, Australian Synchrotron
> 800 Blackburn Road, Clayton, Victoria 3168
> ph: (03) 8540 4164 , fax: (03) 8540 4200
> mailto:[email protected],
> http://www.synchrotron.org.au
> This message and any attachments may contain proprietary or
> confidential information. If you are not the intended recipient or you
> received the message in error, you must not use, copy or distribute
> the message. Please notify the sender immediately and destroy the
> original message. Thank you.
Re: Starting multiple SNL programs Martin L. Smith
Starting multiple SNL programs Andrew C. Starritt
Prev: Re: Building Epics 3.14.10 on Linux Andrew Johnson
Next: epics GUIs (update) Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Starting multiple SNL programs Andrew C. Starritt
Next: Re: Starting multiple SNL programs Martin L. Smith
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
