1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm crashing in execute mode
To: Pierrick Hanlet <[email protected]>, Tech-talk <[email protected]>
Date: Fri, 20 Mar 2009 12:51:11 -0400
Pierrick,
As you know, edm can be a pain to configure. Start by reading the chapter on configuration in the user's manual at http://ics-web.sns.ornl.gov/edm/edmUserManual
Examine $EDMOBJECTS/edmObjects and $EDMOBJECTS/edmPvObjects and make sure all library references make sense.
Also, do ldd `which`/edm and make sure the library locations are what you expect.
John Sinclair
Pierrick Hanlet wrote:
I've developed a fake ioc and some edm panels to view the ioc data. It runs beautifully on my laptop. I've copied the software to our epics server and
now when I attempt to execute the edm panel, edm crashes with a
segmentation fault error.  The only problem appears to be in executing.
Any ideas?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
edm crashing in execute mode Pierrick Hanlet
Prev: RE: How to usr XtAddInput on CA's file descriptors? Jeff Hill
Next: Re: Attribute events; was: Alarm Limits Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: edm crashing in execute mode J. Lewis Muir
Next: Re: edm crashing in execute mode Pierrick Hanlet
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
