1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Attribute events; was: Alarm Limits
To: [email protected]
Date: Fri, 20 Mar 2009 15:34:00 -0500
Hi Ben,
On Thursday 19 March 2009 12:18:53 Benjamin Franksen wrote:
> Since this question/problem comes up so often, I'll take the opportunity
> and hijack this thread to ask why this hasn't been fixed years ago.
Probably because the information about which fields are used for attributes is
currently *only* known to the code in the record type's get_* routines.
There's nothing in the IOC or in any DBD file that says that the EGU field is
used for the engineering units string, or which fields the HIHI..LOLO alarm
limits apply to for example.  I would love to fix this, but it does require
changes to the record support interface to do so automatically.
> According to the spec, CA uses only 3 of 16 available bits for the event
> mask. So let's use a few more of those bits for the most commonly needed
> event types! Even using only /one/ more bit would be extremely useful,
> while retaining complete compatibility at the protocol level:
> DBE_CONTROL	An attribute of the PV has changed. This includes any
> 		attribute of the DBR_XXX_GR and DBR_XXX_CTRL types
> 		other than thos in DBR_XXX_TIME, i.e. stamp, status,
> 		severity, time, value.
Can I propose the name DBE_ATTRIBUTE instead, although I suspect Jeff would
prefer DBE_PROPERTY (which admittedly is shorter).
> Adding this to CA would pave the way.
I just tried this and discovered that CA already transports and handles the
bottom 8 bits of the event mask in R3.14.10+, so with a modified mbbi record
and a modified caMonitor client I am able to change one of the mbbi *ST
fields and see the ENUM strings change in the monitor callback at the client.
The only thing we would need to change to add this is the caeventmask.h file.
> The next step is in the database
> layer, namely at the record support level and in base, where the new bit
> mask must be added to the right db_post_events calls.
Actually we would need to add additional calls to db_post_events(), none of
the existing ones will do the right thing.  When we write a new string to
EGU, we would have to call
	db_post_events(prec, &prec->val, DBE_ATTRIBUTE);
since the VAL field is the one that has the attribute.  Strictly speaking
right now, most record types return EGU as the units string for every field,
so to match that we'd have to post a DBE_ATTRIBUTE update to all fields
whenever the EGU field is modified, but IMHO that's actually a mistake and we
should only be returning EGU for a limited subset of the fields.
There's nothing stopping a record type from doing the necessary work itself
right now, but it would be rather tedious to code.  It would have to mark
every attribute field as special, then have its special() routine look at the
field being written to and call db_post_events() for every other field for
which that particular attribute can be supplied (the record has no way to
know what monitors are in place, so it has to assume every field is monitored
with every DBR_ type and call db_post_events() for all of them).
It would be nice to not have to add special() routines to every record type
just for this though, I'd much prefer to have stuff in the record type's DBD
description for each attribute field and code to dbAccess.c to call
db_post_events() for all the relevent fields whenever an attribute field gets
written to.  We might even be able to automate the writing of the various
get_ routines in the RSET if we do that right.
> However, this can be
> done incrementally, one record at a time. Updating clients can be done,
> too, whenever someone has the time and energy available, there is no hurry
> and no need to closely synchronize developments.
> If I have overlooked some serious drawback in this proposal I'm sure
> someone will point it out soon...
Just the question about how we get db_post_events() called for the right
fields.
The mbb[io] records already mark their *ST and *VL fields as special in order
to recalculate the SDEF field, so for my experiment above I was able to
easily hook into this code and post a DBE_ATTRIBUTE event on the VAL field at
the same time.  Unfortunately MEDM doesn't monitor ENUM fields using a
DBR_CTRL_ENUM type; it only requests the graphical data whenever the channel
connects, so while it is encouraging, my experiment is a long way from being
useful.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: Attribute events; was: Alarm Limits Benjamin Franksen
Alarm Limits Pierrick Hanlet
Re: Alarm Limits Dirk Zimoch
Re: Alarm Limits Benjamin Franksen
Prev: Re: edm crashing in execute mode John Sinclair
Next: Motor problems(RBV can't update itself) Xu, Huijuan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Alarm Limits Benjamin Franksen
Next: Re: Attribute events; was: Alarm Limits Benjamin Franksen
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
