1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Alarm handler: setting group mask via config file?
To: [email protected]
Date: Sun, 22 Mar 2009 16:22:41 -0700
Dear Tech-talk,
I finally have the time to ask this question. When trying to set the default mask via the config file I haven't had any luck when applying it to a group, i.e.
GROUP NULL	HV ---T-
GROUP HV	Boards
However, it works as expected for an individual channel
CHANNEL West_1 TOF:HV:Positive:West:1:14:1:vmon ---T-
Reading through the manual, in version 1.2.23 in Ch. 6 it says under the "Group or Channel" that the mask is only applicable to CHANNEL. However when discussing the sample config file it says:
In this example the default mask "-----" is used for every channel. That is, no masks are specified on the group and channel lines.
Which seems to indicate one can set a mask via the group.
Is there a syntax difference between setting the mask for GROUP and CHANNEL? It would make it considerably easier for me if I could set it in the group else I would need to do it for all 571 channels (could be worse I know).
I am using ALH 1.2.24 on OS X 10.5.6 PPC with EPICS 3.14.9
Bertrand
Prev: Re: epics GUIs (update) Elder Matias
Next: Re: Motor problems(RBV can't update itself) Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Motor problems(RBV can't update itself) Xu, Huijuan
Next: 24 bit ADC Pearson, MR (Matthew)
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
