1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Motor problems(RBV can't update itself)
To: "Gillingham, IJ (Ian)" <[email protected]>
Cc: EPICS <[email protected]>
Date: Tue, 24 Mar 2009 10:35:44 -0400
Hello Ian,
It's a pity that I don't have a spare card.
Huijuan
-----Original Message-----
From: Gillingham, IJ (Ian) [mailto:[email protected]]
Sent: Tuesday, March 24, 2009 5:12 AM
To: Xu, Huijuan
Cc: EPICS
Hello Huijuan,
Reading back through your posts, it appears that the MaxV card in
question was previously working correctly. Do you have a spare card that
you could try in its place?
At Diamond, we have had a number of MaxV cards die on us, some of which
exhibited VMEbus addressing issues and two of which created a lot of
smoke!
Ian
[mailto:[email protected]] On Behalf Of Xu, Huijuan
Sent: 23 March 2009 20:49
To: Ron Sluiter
Cc: EPICS
Ron,
Thanks. I checked that the firmware version is 1.31.1.
Huijuan
Sent: Monday, March 23, 2009 4:34 PM
To: Xu, Huijuan
Cc: EPICS
Subject: Re: Motor problems(RBV can't update itself)
Huijuan,
On second thought, since dbior does not appear to
be working, you should just pull the MAXv boards
out and check the stickers on the upper left corner
for the firmware (FW) version.
Ron
Mark Rivers wrote:
> Ron,
> Isn't there a problem with an older version of the maxV not finding
> boards on reboot sometimes?
> Mark
> ________________________________
> From: [email protected] on behalf of Xu, Huijuan
> Sent: Mon 3/23/2009 1:53 PM
> To: Ron Sluiter
> Cc: EPICS
> Hello,
> It gets more weird today.
> I get "controller is not running. motor_init_record_com(): card does
not
> exit!" errors. The LED on IOvMAX board is green.
> With dbior, I get the following:
>         Oms MAXv motor card #0 @ 0x9FFFF000, id:
> I tried reboot and still the same.
> Regards,
> Huijuan
> From: Ron Sluiter [mailto:[email protected]]
> Sent: Monday, March 23, 2009 10:09 AM
> To: Xu, Huijuan
> Cc: EPICS
> Hello Huijuan,
> Is this a stepper or DC motor?
> Since you mention the ERES field, I'm guessing this is a DC
> motor. What is the value of the MIP field when the motor
> is stuck in the Moving state?
> Ron
> Xu, Huijuan wrote:
>> Hello,
>> I'm using OMS MAXv motion controller. The motor record version is
6.3.
>> The motor worked well several days ago with this version but goes
>> weird when I use it today.
>> RBV field can't update automatically. I have to reset the MRES or
ERES
>> field and just the two fields to update RBV.
>> MOVN kept 1 all the time after motor began its first moving. DMOV
does
>> not reset to 1 after position is reached.
>> Many thanks.
>> Regards,
>> Huijuan
This e-mail and any attachments may contain confidential, copyright and
or privileged material, and are for the use of the intended addressee
only. If you are not the intended addressee or an authorised recipient
of the addressee please notify us of receipt by returning the e-mail and
do not use, copy, retain, distribute or disclose the information in or
attached to the e-mail.
Any opinions expressed within this e-mail are those of the individual
and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Ltd. cannot guarantee that this e-mail or any
attachments are free from viruses and we cannot accept liability for any
damage which you may sustain as a result of software viruses which may
be transmitted in or with the message.
Diamond Light Source Limited (company no. 4375679). Registered in
England and Wales with its registered office at Diamond House, Harwell
Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United
Kingdom
RE: Motor problems(RBV can't update itself) Xu, Huijuan
RE: Motor problems(RBV can't update itself) Gillingham, IJ (Ian)
Prev: RE: Motor problems(RBV can't update itself) Gillingham, IJ (Ian)
Next: JCA2 vs CAJ? GaryCarr
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Alarm handler: setting group mask via config file? Bertrand H.J. Biritz
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
