1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Motor problems(RBV can't update itself)
To: "Ron Sluiter" <[email protected]>
Cc: EPICS <[email protected]>
Date: Mon, 23 Mar 2009 16:49:14 -0400
Ron,
Thanks. I checked that the firmware version is 1.31.1.
Huijuan
-----Original Message-----
Sent: Monday, March 23, 2009 4:34 PM
To: Xu, Huijuan
Cc: EPICS
Subject: Re: Motor problems(RBV can't update itself)
Huijuan,
On second thought, since dbior does not appear to
be working, you should just pull the MAXv boards
out and check the stickers on the upper left corner
for the firmware (FW) version.
Ron
Mark Rivers wrote:
> Ron,
> Isn't there a problem with an older version of the maxV not finding
> boards on reboot sometimes?
> Mark
> ________________________________
> From: [email protected] on behalf of Xu, Huijuan
> Sent: Mon 3/23/2009 1:53 PM
> To: Ron Sluiter
> Cc: EPICS
> Hello,
> It gets more weird today.
> I get "controller is not running. motor_init_record_com(): card does
not
> exit!" errors. The LED on IOvMAX board is green.
> With dbior, I get the following:
>         Oms MAXv motor card #0 @ 0x9FFFF000, id:
> I tried reboot and still the same.
> Regards,
> Huijuan
> From: Ron Sluiter [mailto:[email protected]]
> Sent: Monday, March 23, 2009 10:09 AM
> To: Xu, Huijuan
> Cc: EPICS
> Hello Huijuan,
> Is this a stepper or DC motor?
> Since you mention the ERES field, I'm guessing this is a DC
> motor. What is the value of the MIP field when the motor
> is stuck in the Moving state?
> Ron
> Xu, Huijuan wrote:
>> Hello,
>> I'm using OMS MAXv motion controller. The motor record version is
6.3.
>> The motor worked well several days ago with this version but goes
>> weird when I use it today.
>> RBV field can't update automatically. I have to reset the MRES or
ERES
>> field and just the two fields to update RBV.
>> MOVN kept 1 all the time after motor began its first moving. DMOV
does
>> not reset to 1 after position is reached.
>> Many thanks.
>> Regards,
>> Huijuan
RE: Motor problems(RBV can't update itself) Gillingham, IJ (Ian)
Motor problems(RBV can't update itself) Xu, Huijuan
Re: Motor problems(RBV can't update itself) Ron Sluiter
RE: Motor problems(RBV can't update itself) Xu, Huijuan
Prev: Re: environ symbol on MacOS X with EPICS base 3.14.10 Bill Lavender
Next: RE: MEDM Comm. Failure / STATE Richard Pastrick
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Motor problems(RBV can't update itself) Ron Sluiter
Next: RE: Motor problems(RBV can't update itself) Gillingham, IJ (Ian)
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
